Head gasket....
Old Sep 19, 2003 | 12:00 PM
UNDER PRESSURE's Avatar
Default Head gasket....
My B16A crx just started leaking alot of oil from where the head meets the block does that mean my head gasket is gone?
Old Sep 19, 2003 | 01:01 PM
Hondasaurs's Avatar
Default Re: Head gasket.... (UNDER PRESSURE)
Where is the oil coming from (which side?)
Most likely it's the cam sealthats causing your oil leak.
Old Sep 19, 2003 | 02:46 PM
Default Re: Head gasket.... (Hondasaurs)
No it's not the cam seals. That's the first thing that I checked. It's where the head meets the block, does that mean that the head gasket is out or does that mean I have to resurface the head?
Old Oct 3, 2003 | 01:44 PM
kagegod's Avatar
Bump cause I have the same problem and I'm wondering what it is
Old Oct 3, 2003 | 02:26 PM
spaceman's Avatar
Default Re: (kagegod)
i think its the head gasket and if you remove it carefully you shouldnt have to do any resurficing...
Old Oct 3, 2003 | 02:49 PM
mattduskater's Avatar
it is moste likely the gasket, or the head isnt tightend on enoughf. turn the engine over a couple of times and take out each spark plug one at a time and look for coolant on the plug. If there is coolent you have a blown head gasket.
but to be on the safe side carefully remove the head and take it to a machine shop to have it checked. big project im in the process of it now.
Old Oct 6, 2003 | 08:37 AM
kagegod's Avatar
I changed all the valve cover seal and the seals for the spark plug wells and then drove it about 350 miles this weekend and I haven't had one hint of oil in the spark plug wells or coming from underneath the valve cover.
H22AJSPEC
Dec 3, 2010 01:50 AM
jdmitrdc2
Apr 15, 2009 11:31 AM
civicvtec16
Oct 29, 2006 10:45 AM
GDM Z28
May 6, 2004 04:28 PM
