vafc, where to set the vtec...
Old Sep 19, 2003 | 12:00 PM
ludeR917's Avatar
Default vafc, where to set the vtec...
just installed my vafc, but it is not tuned yet. i just want to keep it at the stock settings till i get some cams and some headwork. anyways my question is where do i set the vtec at? right now i got it at high=5200 and low=5100. thanks for any help.
Old Sep 19, 2003 | 12:28 PM
PetroGuyX's Avatar
stock it kicks in at 5 right? so i'd say somewhere around there it would be good, or where ever stock starts, i can't remember if it's 5k or 6k, but i'd think you'd be aight somewhere around there
Old Sep 19, 2003 | 01:52 PM
PretecSH's Avatar
Default Re: (PetroGuyX)
pretty sure stock is at 5400(maybe 52). i have heard for our cars, 4800 and 4700 is ideal. thats what im set at.
Old Sep 19, 2003 | 08:47 PM
azndng's Avatar
Default Re: (PretecSH)
i heard one guy put it at 3100rpm. I guess he likes to hear vtec cruising at 70mph. Vtec cross over for h22 is between 5200, it may seem like 5400 cause the rpm will surge really fast.
-some say to set vtec at lil lower then stock, so you don't have to rev to 8k so you don't fall out of vtec.
.02
Old Sep 19, 2003 | 08:50 PM
sslude's Avatar
Default Re: (azndng)
5th generation engages at approximately 5200. i would set it at 4800. i dont think the secondaries open up till 4900. so why would you want vtec engaged when you're not getting much need air
Old Sep 19, 2003 | 08:51 PM
4bidden's Avatar
Like someone mentioned.....around 4700 is where most VAFCs end up after tuning.
Old Sep 19, 2003 | 09:16 PM
piotrush's Avatar
Default Re: (4bidden)
I have mine set at 4200. The powercurve has no more dip
Old Sep 19, 2003 | 09:24 PM
fizzbob7's Avatar
Default Re: (piotrush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piotrush &raquo;</TD></TR><TR><TD CLASS="quote">I have mine set at 4200. The powercurve has no more dip
the small cam lobes should make power up to exactly 4750rpm....setting the crossover at 4700 is ideal with a stockish setup, or at least the stock cams.....anything else means your fuel consumption will increase and that is kinda the point of VTEC
Old Sep 19, 2003 | 09:40 PM
piotrush's Avatar
Default Re: (fizzbob7)
For some reason there was still a dip when we set it at 4600 or 4700, thats why we lowered it. we-todd-did is down now but I'll try to put up a dynoplot later.
Old Sep 19, 2003 | 11:13 PM
DsITR's Avatar
Default Re: vafc, where to set the vtec... (ludeR917)
You really shoudln't touch it until dyno tuning..
we all know how accurate the butt dyno is. and you have no way of knowing if you are running lean or rich.
tuckin15s_8315
Jun 21, 2005 03:13 PM
South Bay Surfer
Oct 3, 2003 11:49 PM
DjDrift
Oct 3, 2003 08:42 PM
civictuned
Aug 1, 2003 04:36 PM
NeXtLeVeL_TyPe_R
Nov 13, 2001 04:05 PM
