HELP! I can't figure out what this plug is for!
Old Sep 19, 2003 | 10:26 AM
allmotorEG-SI's Avatar
Default HELP! I can't figure out what this plug is for!
There is a hose that connects to my steering rack, its used for power steering fluid. Right before it connects with the steering rack at the bottom of it is a green plug with 2 prongs coming off of it and I can't figure out for the life of me what the hell it'd be used for. Does anybody have any ideas?
Old Sep 19, 2003 | 10:51 AM
axhandler's Avatar
Default Re: HELP! I can't figure out what this plug is for! (allmotorEG-SI)
Padawan can probably answer this question...try PM'ing him. Also try reading some of his posts you might be able to figure it out that way.
Good luck!
Old Sep 19, 2003 | 10:53 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorEG-SI &raquo;</TD></TR><TR><TD CLASS="quote">There is a hose that connects to my steering rack, its used for power steering fluid. Right before it connects with the steering rack at the bottom of it is a green plug with 2 prongs coming off of it and I can't figure out for the life of me what the hell it'd be used for. Does anybody have any ideas?</TD></TR></TABLE>
Why don't you go look at it again and then tell us where it attaches to, wiring-wise. The knock sensor plug is back there in the vacinity.
Also, what kind of motor is it and what chassis?
Old Sep 19, 2003 | 11:36 AM
tonyxcom's Avatar
Default Re: HELP! I can't figure out what this plug is for! (Archidictus)
ITs the PSP or Power Steering Preassure Switch.
Circle plug, 2 pin, Green.
Old Sep 19, 2003 | 11:54 AM
Default Re: HELP! I can't figure out what this plug is for! (tonyXcom)
so what do I do with it. I've got a 94 Si with a b18b engine and no power steering. I wanted to hook it up to(for many reasons) But I didn't know what to do with that plug. What connects to it. All I know about the power steering is there is a hose connected to my steering rack, that hose goes to the top of the pump, the bottom of the pump connects to a resivoir tank and than a belt betweent the pump and crank pulley. So what about that "PSP switch?" How does it fit into all of that?
Old Sep 19, 2003 | 11:59 AM
tonyxcom's Avatar
if your steering rack doesn't have the preassure switch on it, don't worry about.
Just tie the plug out of the way.
Old Sep 19, 2003 | 12:56 PM
all stock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom &raquo;</TD></TR><TR><TD CLASS="quote">ITs the PSP or Power Steering Preassure Switch.
Circle plug, 2 pin, Green.</TD></TR></TABLE>
correct. you can cut the plug if u don't need it.
dsy29
Aug 5, 2010 09:44 PM
b20beast83
Suspension & Brakes
Oct 21, 2008 01:31 PM
BIG T
Aug 23, 2007 06:04 AM
muha man
Jan 9, 2007 09:31 PM
hondime9396
Nov 21, 2004 09:46 PM
