Car cranks and cranks, but won't start
Old Sep 19, 2003 | 10:08 AM
tboss's Avatar
Default Car cranks and cranks, but won't start
I have an intermittent problem that does not occur all of the time. Sometimes when I get in my 90 Accord, it turns over and just cranks and cranks, but won't start. Took it in to the mechanic, and of course it started every time so they couldn't tell for sure what the problem was. Any ideas?
Old Sep 19, 2003 | 10:34 AM
seppuku's Avatar
More info please. When does it happen (cold or hot)?
Old Sep 19, 2003 | 10:54 AM
tboss's Avatar
Most of the time when it is cold. It has happened just a couple hours after we've driven the car.
Old Sep 19, 2003 | 11:07 AM
tpr's Avatar
tpr
Default Re: (tboss)
You are in Houston it may be the main relay. This is a coomon problem when the interrior gets hot. Does it have spark when it is cranking or does it not turn over. Can you hear the fuel pump run for a few seconds when you first turn on the iginition. The main relay develops cracks in the solder joints. the fix is to open up the relay and reflow the solder joints on the cricuit board or if you are not handy with the soldering pencil just go buy a new one and put it in. Generally its on the drivers side undr the dash. Search on main relay for pics etc.
Old Sep 19, 2003 | 12:37 PM
pro1342's Avatar
Definitely main relay. While sitting in the car , start cranking and bang the dash by your left knee. The jolt should be enough to kick in the relay. If not, reach underneath the dash, above the fuse box, and bang directly on the relay.....should start. Or, just get a new one.
Old Sep 26, 2003 | 06:25 AM
tboss's Avatar
Default Re: (pro1342)
Is the main relay hard to replace? Do we get it from Honda or any car parts store?
Old Sep 26, 2003 | 06:30 AM
pro1342's Avatar
Easy to replace....one bolt and one connector. It is about $55 from Honda.
trevorjohn88ef
Nov 12, 2010 01:35 AM
nismogrendel
Apr 24, 2010 01:43 AM
fastfox1306
Jan 29, 2010 10:34 PM
bobwallace
Aug 6, 2008 04:42 AM
90jdmcrxdude
Aug 5, 2006 07:34 AM
