OT - relation between tires diameter and reading on speedometer?
Old Sep 19, 2003 | 10:01 AM
Nuts's Avatar
Default OT - relation between tires diameter and reading on speedometer?
Did a search, couldn't find the answer I am looking for.
Install tires with bigger overall diameter (compare to OEM) would throw the speedometer reading off... but is it going to overstate or understate the speed reading??
btw, Mod. if this is not an appropriate forum to post, move as needed.
Old Sep 19, 2003 | 10:17 AM
PyR01-0347's Avatar
Default Re: OT - relation between tires diameter and reading on speedometer? (01-1194)
It will understate your speed.
Old Sep 19, 2003 | 10:18 AM
ZygSpeed's Avatar
Bigger diameter tires (i.e., axle rotates slower for a given speed), speedo reads slower.
Old Sep 19, 2003 | 11:31 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: OT - relation between tires diameter and reading on speedometer? (zygspeed)
I think of it this way.
With bigger tires, the car goes further with each axle revolution, so the car doesn't "know" it is going as fast as it actually is (because it assumes the tires are smaller). So the speedo reads low.
Old Sep 19, 2003 | 01:18 PM
Chris N's Avatar
Default Re: OT - relation between tires diameter and reading on speedometer? (nsxtasy)
195/55-15 is the stock size.
Let's use some real examples to help out.
195/50-15, 205/50-15 - both smaller in diameter. More rotations.
195/60-15 - larger in diameter, less rotations.
Plug these numbers into the Tire Size Calculator on Miata.net and you get:
Temporary replacement link: (WTDR down)
Copy and paste in browser, stupid yahoo.
http://www.geocities.com/cnica...e.gif
This shows the percentage difference. A smaller diameter tire will read 'higher' on the speedmeter, which is given in percent on the chart above.
So... on my 195/50-15's, at an indicated 100mph, I am reading 3.3mph faster than I am going, PLUS whatever speedometer error there is inherent in the system. (Since there is no accurate calculation of this error, let's just say it's negligable for sake of discussion...) so you are actually going 96.7mph.
The opposite is true with a larger diameter tire. These will read slower than you are really going. So going 100mph with 195/60-15's, an indicated 100mph is really 103.3mph.
It's pretty minor, when you are talking about tires within 3.5% of each other. Just remember, it is PERCENT, so at 15 mph you aren't really going +/- 3.3 mph, it is much smaller than that.
Hope this helps.
Old Jan 31, 2011 | 06:25 AM
G. Man's Avatar
Nice! always wondered about that.
Old Jan 31, 2011 | 06:36 AM
itrSteez's Avatar
Awesome bump, almost shy of a full ****ing decade.
Old Jan 31, 2011 | 07:44 PM
94eg!'s Avatar
#1 Super Guy
Loved
Old Jan 31, 2011 | 08:14 PM
94eg!'s Avatar
#1 Super Guy
Loved
killercrx91
Apr 15, 2009 10:24 AM
tazeat
Dec 9, 2008 08:16 PM
jbashir
Aug 3, 2005 11:17 AM
TrueDC2
Jun 24, 2003 04:17 AM
Turtle
Oct 8, 2001 01:55 PM
