what size tires for 16's
Old Sep 19, 2003 | 09:49 AM
EKtypeRhaTcH's Avatar
Default what size tires for 16's
im getting some new 16' rota subzeros but im not shure what tire size to put on it? i have 15' rota c8s right now and i my tires are 195-50-15, so im looking at either 205-50-16 or 205-45-16 which one should i get?
Old Sep 19, 2003 | 09:51 AM
-Gambit-'s Avatar
Default Re: what size tires for 16's (EKtypeRhaTcH)
205/45/16 is the correct tire size
Old Sep 19, 2003 | 09:55 AM
opi's Avatar
opi
Default Re: what size tires for 16's (Evil_gambit33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil_gambit33 &raquo;</TD></TR><TR><TD CLASS="quote">205/45/16 is the correct tire size</TD></TR></TABLE>
yup, that would be your best bet
Old Sep 19, 2003 | 10:37 AM
axhandler's Avatar
Default Re: what size tires for 16's (opi)
Actually your all wrong. 205/40-16 is the closest to the overall diameter of the 195/50-15.
A little math to help you...not that many people know how tire sizes work. The first number is the width of the tire in millimeters and the second is the aspect ratio. Aspect ratio is height of sidewall divided by the tire width * 100.
OK...knowing this lets calculate the overall diameter of the tires...
Multiply the first number by the second one divided by 100. (205*(40/100)) = 82mm = Sidewall height
(82mm * 2)*.0393 = 6.457 in = total sidewall height in inches. the .0393 is the conversion factor.
6.457 + 16 = 22.46 in = overall diameter of the 205/40-16
Do the same thing for the 195/50-15 and you get 22.68 in
For 205/45-16 you get 23.26.
Summary:
Size Overall Diameter (in)
195/50-15 22.68
205/50-16 24.07
205/40-16 22.46
205/45-16 23.26
You want your overall diameter to be as close as possible or youll throw your spedo. off.
Any Questions? Feel free to ask.
Old Sep 19, 2003 | 11:35 AM
blackeg's Avatar
Default Re: what size tires for 16's (axhandler)
205/40/16
Old Sep 19, 2003 | 11:48 AM
cre18's Avatar
Default Re: what size tires for 16's (blackeg)
i used to rub in the rear with my 205/45/16's when i was too low. i've adjusted the height and solved the problem but i wonder if i bought 40 series tires, if i would prevent rubbage?
what brand of tires are you looking at?
Old Sep 19, 2003 | 11:53 AM
akaEsCo01's Avatar
the sidewalls on 205/40's are really thin, i would go with the 205/45
Old Sep 19, 2003 | 11:59 AM
EARLdaSQUIRREL's Avatar
official honda whore
i have 205 40's on my slips and it seems as if there is no sidewall... in the future id go with a 205-45 and get a little extra sidewall
Old Sep 19, 2003 | 12:02 PM
Bodman's Avatar
Default Re: (coptzer)
205/40/16
sidewall ugly
rim purty
Old Sep 19, 2003 | 12:09 PM
STIBungy's Avatar
Why are you comparing it to 195/50/15? 195/55/15 is what comes with the Integras and some civics. 205/45/16 is a more accurate plus 1 size for 195/55/15.
Old Sep 19, 2003 | 12:16 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: what size tires for 16's (B18CBungy)
I run 205/40/16. The only problem is tire choices aren't the greatest. I like the way that size looks on 16's the best.
I know I'd scrub like hell if I went with a 205/45/16 or higher.
Old Sep 19, 2003 | 12:41 PM
jg's Avatar
jg
Here's an easier formula...
width(in mm) times the aspect ratio(percentage, hence the decimal ) divided by 12.7(conversion from metric to standard) plus the wheel diameter. Examples below...
205/45-16 tire...
205 x .45 / 12.7 + 16 = 23.26
215/40-16...
215 x .40 / 12.7 +16 = 22.77
and so on.....
Old Sep 19, 2003 | 12:45 PM
pro1342's Avatar
I have the same rims, currently with 205/45/16. Previously, I had 215/40/16. The 215's handled better, but the 205's have a better ride.
Old Sep 22, 2003 | 06:24 AM
axhandler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CBungy &raquo;</TD></TR><TR><TD CLASS="quote">Why are you comparing it to 195/50/15? 195/55/15 is what comes with the Integras and some civics. 205/45/16 is a more accurate plus 1 size for 195/55/15.</TD></TR></TABLE>
You raise a good point...OE tire should be 195/55-15. In which case you are correct 205/45-16 would be the correct tire size.
I was going by his original statment that he had 195/50-15's currently.
Old Sep 22, 2003 | 03:57 PM
STIBungy's Avatar
Word
Old Sep 22, 2003 | 04:02 PM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axhandler &raquo;</TD></TR><TR><TD CLASS="quote">
I was going by his original statment that he had 195/50-15's currently.</TD></TR></TABLE>
Also, the 5G, 6G, and 7G civs all come with different stock tire sizes.
95EX 185/60/14 g/f's car
98EX 185/65/14 my car
02EX 185/70/14 g/f's sister's car
mortificationrock
67
Jun 11, 2008 05:42 PM
CeNCaL-DA9
Sep 4, 2007 09:10 PM
99delsol
Dec 11, 2006 06:10 AM
yeaaaa its slow
Nov 25, 2003 08:03 PM
IntegraBoy04
Sep 26, 2003 02:22 PM
