200 whp
need 200whp. i already have the following mods done to my b18c. need more power......HELP...... need header advice but cant SMSP.
aem cai
jg throttle body
skunk2 intake manifold
rc 310 injectors
5 angle valve job and port & polish
skunk2 spring & retainers
ferrrea valves
skunk2 stage 2 cams
str cam gears
jdm p30 pistons
jdm b16a tranny w/ LSD
skunk2 stage 2 cams
aem cai
jg throttle body
rc 310 injectors
ferrrea valves
skunk2 stage 2 cams
str cam gears
jdm p30 pistons
skunk2 stage 2 cams
made 190 whp with a dc sports header and stock gsr tranny but the header is dented and i took it off. would a fuel pressure regulator and ignition help or what?
i made 200whp with similar modz, i have a jdm 4-1 header which is good for mild cams... get the fpr with gauge vafc, and a chipped ecu.. you should make over 200whp since the skunk stage 2 cams peak out at 8700rpms.. oh yeh light rims on the dyno will also help out acheving your goals..
I think all you need to make 200 whp is custom header. Assuming you are already making 190whp. Most of the dyno results of custom headers produce a minimum of 10whp.
That dented DC sports header is REALLY holding you back. Id say even with a JDM DC type R header youl hit 200, but u might as well get a good piece and be done with it. Header-tech is a lot of header for the money.
cliff666
14
Jul 30, 2005 11:30 AM
91integraLSVTEC
Sep 28, 2004 07:21 PM
