need help asasp!!!!!please
Old Sep 19, 2003 | 01:55 AM
ef9one6's Avatar
Default need help asasp!!!!!please
ok heres the problem i have a 91 civic si, i drove to work and the car was fine, then as i leave from work the car feals like its struggling hella bad and starts putting and kinda jerking and my rpm guage goes crazy . i park and turn it off, then i try to turn it back on and it wont all it does is make a fast cliking noise! i got a jump and the car turned on then i try to drive all power seems to dye out and when i press on the gas theres no throttle responce.
wtf is wrong? any info would be greatly apreciated!
oh yea theres alot of white smoke comming out the exuast
Modified by ef9one6 at 12:05 PM 9/19/2003
Old Sep 19, 2003 | 04:59 AM
DJ_SaNdOz's Avatar
Default Re: need help asasp!!!!!please (ef9one6)
check compression. Is your coolent low? What color is your oil?
Old Sep 19, 2003 | 05:20 AM
Phatwhippin_CRX's Avatar
Default Re: need help asasp!!!!!please (DJ_SaNdOz)
your dizzy is shot
Old Sep 19, 2003 | 05:29 AM
Jet Black's Avatar
Well for one your battery was dead, so my theory is your alt aint charging properly. Which would explain why the car is drying, with low power it will heistate like a mother.
If you can get it to turn over again, check the voltage at the battery poles, should be something like 14.x volts when the car is running...if not, something is up with your alt....could be corrosion in the connector...more than likely the alt is toast.
As for the hesitation due to increased throttle, you mgiht not be making enough power to create sparks all the time.
Check your alt first
Then I'd consider your distro.....but I'm still curious as to why your batt we be low.
BTW never boost a battery if the voltage is lower than say 11 volts....or you'll fry it.
Old Sep 19, 2003 | 07:09 AM
Default Re: need help asasp!!!!!please (Jet Black)
his battery died because he repeatedly tried to start it, right? most likely......
also, check you cat and see if it's clogged up. good chance it is.
Old Sep 19, 2003 | 01:34 PM
ef9one6's Avatar
Thanks for all the info it is greatly apreciated ill check all of the above!
dices543
16
Sep 21, 2010 01:47 PM
uneek360
Jul 3, 2007 11:48 AM
jdmCivic925
Aug 22, 2004 05:53 PM
DoctorGSR
Feb 7, 2004 09:47 PM
