Is B15 the RPM signal on a PW0/PR3 ecu?
Old Sep 18, 2003 | 09:15 PM
SC0TT's Avatar
Default Is B15 the RPM signal on a PW0/PR3 ecu?
Im hooking up a VAFC on a PW0 ecu. Everything went fine except there is no RPM signal hooked up. I was told it was suppose to be ran off pin B20, but no luck. Anyway, Ive done some searching and found a couple posts saying it was pin B15..according to the hasport wiring diagram, this is an Ignition Control Module.
http://www.hasport.com/Tech/Wr...R.htm
Can someone confirm B15 is the RPM Signal. If not, which pin is it???
Thnks-
Old Sep 19, 2003 | 07:14 AM
EF_LSVtec's Avatar
Default Re: Is B15 the RPM signal on a PW0/PR3 ecu? (SC0TT)
i found some information on the apexi site...sorry too lazy to read through the instruction manual...its been a while since I installed one. Here's the site anyway..
http://www.apexi-usa.com/produ...c.pdf
CRX.EBS
Nov 9, 2005 12:22 AM
Moemers
Honda S2000
Jul 12, 2005 09:27 AM
Dran
Apr 28, 2004 06:04 PM
