valve cover gasket replacement..
you need the seals that go around the spark plugs hole
and the valve cover seals that go where you bolt down your cover
[QUOTE=DRAG lll INTEGRA]and maybe some honda bond,QUOTE]
Definitely get some kind of thread-locker but don't get the kind that requires heat or anything to remove, my valve cover nuts kept coming loose on me until I got some of this stuff.
Yes. or go to any auto parts store and ask for the anti-seize/thread locker section. i bought some recently and there was a blue and a red.. the red is the tougher of the 2 that requires heat to get the nut removed once it's locked so be sure to get the blue. the big tube is like $25 so get the smaller one it's like 4 bucks.
The last time I changed my valve cover gasket and plug rings, I also replaced most of the rubber grommets that the valve cover bolts tighten against.
parts #23
parts #23
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp »</TD></TR><TR><TD CLASS="quote">The last time I changed my valve cover gasket and plug rings, I also replaced most of the rubber grommets that the valve cover bolts tighten against.
parts #23</TD></TR></TABLE>
Sort of off topic but are the JDM grommets the same as USDM grommets? I look at valve covers on cars from japan and their grommets are silver while the ones i have are black.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Silver ones are from a type r.</TD></TR></TABLE>
bling for the hype Arrrrrrs
ahhhh, i guess now ill have to get some silver grommets
