throttle position sensor- voltage output wire
Old Sep 18, 2003 | 05:54 PM
7808's Avatar
Default throttle position sensor- voltage output wire
can anyone tell/show me where it is real quik?
Old Sep 18, 2003 | 06:39 PM
jdmzim's Avatar
Default Re: throttle position sensor- voltage output wire (summerDumpster)
if you go to Tech.hybridgarage.com/tech/5gtech.html then scroll down to wireing click on that then down to gsr wireing digram page1 or page2 that should tell you where the voltage wire comes off the ecu. gsr and prelude wireing are the same except the egr valve
Old Sep 18, 2003 | 10:09 PM
7808's Avatar
Default Re: throttle position sensor- voltage output wire (jdmzim)
thanks i'll check it out. anyone got a picture?
Old Sep 19, 2003 | 01:09 AM
7808's Avatar
i cant find it on that site can anyone tell me where to look/ what wire im lookin for?
Old Sep 19, 2003 | 10:36 AM
99_SH's Avatar
Ok, look at the TPS sensor(located on back of throttle body). Hook up a voltmeter from the center wire of the TPS to ground, you should be reading .45 Volts. If its no within spec, just rotate the TPS(undo the 2 bolts first) until you get a reading around .45
Old Sep 19, 2003 | 10:45 AM
7808's Avatar
Default Re: throttle position sensor- voltage output wire (99_SH)
nevermind
Modified by summerDumpster at 11:09 AM 9/21/2003
n20sol
Dec 17, 2005 10:28 AM
thaimonkee
Mar 10, 2005 02:54 PM
