RSR Exhaust and ITR Rear Sway
I have an RSR cat-back exhaust on my GS-R right now. It's the old style canister-type exhaust not the new one that resemble the n1s. I was just wondering if there would be any problems if I install an ITR rear sway bar on my car? I'm just worried that the D-brackets would rub against the back of the exhaust. Any help would be appreciated. Thanks.
Do you have any problem with the RSR hitting your stock swaybar? If not, then I would think that it would not hit with the Type-R rear swaybar.
They do? I had the exact same setup - clearedn nicely on mine... used the hybrid page install for the itr bar, no probs that i knew of..
things that make ya go hmmmmmmm
lol
lol
i have the RS*R cat-back exhaust with the BSQ ITR swaybar kit and i dont have any problems with rubbing or anything. but the damn camber kit squeaks like a pig when its cold outside! :D
No, I haven't put on the rear sway bar yet but was just wondering if there would be a clearance issue with the larger D-brackets that hold the sway bar.
BSQ - I have a question about your kit. I see now that you included two washers in your kit. I bought your kit awhile ago when it included the medal plate and the spacer. Will I need those two washer for the install?
D50boy
Nov 10, 2008 04:55 AM
crexer
Oct 30, 2006 09:50 PM
deviant1
Nov 6, 2002 12:55 PM
