B18B and AC in a 89 CRX Si?
i've done a b18a swap and kept the a/c in a 88 crx std.only problem was the a/c lines are close to the fans and header,but they do fit with some tweaking...and i used a place racing a/c mount,which was a total pos.it came with 2 stripped bolt holes and the mounting holes for the compressor were tapped crooked.but other than that,a/c is no problem
I have a b17a transplant using hcp mounts and i also have a/c. The a/c fan will fit behind the radiator, its a very close fit between the radidator and the header. I had a/c compressor from my hf motor frabricated on to the b17. I have not had any problems yet.
OldSkOOlReX
Apr 29, 2004 12:52 PM
