88hf crx with tons of mods in florida
I have a friend that was come into some financial problems. The car is a 88hf crx. There is a lite rust in the rear fender but it is very minimal, other than that body is perfect. The interior is in perfect shape and has 88-89si crx seats. It also has a 90 tach and cluster cover. A/c controller is perfectly intact. THE CAR IS A ROLLONG CHSSIS THAT WAS AWAITING A MOTOR SWAP.The car has extensive suspension mods done to it. They include all BRAND NEW PARTS WITH ZERO MILES AND RECIEPTS. The front sway bar is out of a 90si crx, rear sway bar is suspension techniques adjustable sway bar. It has new upper control arms(factory honda), all new ball joints, brand new crx si rack & pinion, ingalls front and rear camber kit, energey suspension polyurethane master kit and also all none included bushings. Every bushing has been replaced from enery suspension and is new and everthing that needs to be pressed has in has already . The brakes consist of 90-91 civic ex(10.3) with new calipers, and bremblo blanks rotors, it even has new wheel bearnigs. The rear brakes consist on 92 integra rear trailing arms with new bearings, bushings, brembo roters. It also has goodridge stainless steel braided lines all the around. The master cylinder, brake bosster, and prop valve is from an 92integra and is all in the car also. The shocks are koni yellows and it has eibach sportline springs. It also comes with engine harness, injectors, and resistor box. Car has 99si vtec fuel pump. For and extra $125 He will throw in a obd1 conversion harness had by blownhatch on homda-tech. I am sure we have left a few things about But this as you can se that this is a 88hf wich is the ligfhtest crx and has the ultimate setup This car only needs brake pads and a engine swap to be the ultimate honda. There are easily over $2000 worth of recipts for parts. He is taking offers and really does not want to goes through the hassle of parting it out. We are goin to take some pics and will have them this evening
click link for pics:
http://www.tamparacing.com/for...09623
$2000 and tell your buddy to sell the brand new koni sports for $400 and he has his car for $1600. car only has a single small bit of rust on a rear fender. other than that the car is mint with 110% new suspension. Every peice down to the wheel bearings has been replaced
seller is very motivated if anyone is interested give him a call. He will probally go down to $1800. his name is larry 407-342-5221. It's not everyday you see a clean 88hf with all this work done for 75% of reciepts in hand. Have I metioned that all parts are new. I guarentee you will not be able to buy another hf for any price and even come close to what this has to offer.
If someone wants this car for less money with stock suspension please let me know and maybe me and you can wok something out. I need alot of parts off the suspension and can replace them with stock parts. Im me and maybe we can work something out.
CRX_Honda
27
Feb 26, 2009 11:35 AM
