*** Selling my 4th gen (1990) Accord! :( ***
https://honda-tech.com/zerothread?id=623276
car is for sale in Southern Ontario, Canada. Has to go, new "wheels" coming!
P.S. Car has black window mouldings and a new paint now!
thanks bud, i would be willing to deliver withing a reasonable distance in the U.S., but '90 Accords require the motorized belts in the states due to lack of driver side airbag...
I'm hoping to find someone local here in Canada to "adopt" it!
I'm asking $6500 CDN or best offer. For all Ontario residents, the car is e-tested and certified, so it's ready to go!
I have receipts for most everything along with normal maintaince items (oil changes, rad flush, etc, etc).
Dynoed (before the EX-R header, lightened flywheel, clutch) @:
113.7hp@4900rpm(at the wheels)
135.3ft-lb@3900rpm(at the wheels)
The car has shaved side mouldings and rear bumper moulding (very unique) and it was repainted this past July... below is the list of all the mods...
Front Bumper -- WingsWest 890428 (Big Mouth II)
17" Wheels -- ADR N/A (DTM)
215/45ZR17 Tires -- Kuhmo N/A (Ecsta Supra 712)
Cross Drilled Rotors -- Ractive 320770 (Left) 320870 (Right)
High Friction Brake Pads -- AEM 26-115 (Nissin Calipers)
Lowering Springs -- NEUSPEED 55.20.11 (Sport)
Gas Struts Tokico -- HU3714 (HP Front) HU2781 (HP Rear)
Adjustable Front Camber Kits -- Ingalls 3572
Front Lower Ball Joints -- McQuay-Norris (just installed)
Front Upper Ball Joints -- Honda O.E.M. (just installed)
Outer Tie-Rod Ends -- Honda O.E.M. (just installed)
Rear Upper Ball Joints -- McQuay-Norris (just installed)
Front Upper Tie-bar -- Ractive H-041/1
Rear Upper Tie-bar -- Ractive H-042/1
Rear Lower Tie-bar -- OBX-R OBTX-H1005A
Rear Sway Bar (13/16") -- Suspension Techniques 51120
Polyurathane Front Sway Bar Links -- Energy Suspension 16.8105.R (Red)
Polyurathane Front Engine Mount Insert -- Energy Suspension 16.1107R (Red)
Cold Air Intake -- Ractive 22265 (Silver)
Hi Flow Air Filter -- K&N RU-3570
Bypass Valve -- AEM 20-401S
4-2-1 EX-R Header -- Honda O.E.M.
O2 Sensor (EX) -- NGK
2&1/4" Hi-Flow Cat -- Carsound
2&1/4" Hi-Flow Resonator
2&1/4" Rear Muffler -- Ractive MT-228
9mm Ignition Wires -- Ractive
Radiator/Braided Hoses (1 year old)
'90 EX-R Transmission -- Honda O.E.M.
Lightened Flywheel -- RAM Cylinder Heads Machine Shop N/A (custom machined O.E. part)
Clutch -- RhinoPac HD
Short-Throw Shifter -- NEUSPEED 66.20.34
Indiglo Gauge Faces (km/h) -- Ractive EL-605
Air/Fuel Ratio Gauge -- Autometer 5775 ('Phantom')
Oil Pressure Gauge -- Autometer 5727 ('Phantom')
A-Pillar Dual 2&1/16" Gauge Pod -- Gauge Works by AutoMeter 20112 ('94-'01 Acura Integra Pod--Tan)
Deep Cycle Battery -- Optima D38/78 8012-021 (Yellow Top)
Projector Headlights -- APC 40.3523.HL
'Euro' Corners -- APC 40.3060.CLE
Smoked Bumper Lenses -- Eurolite/Toucan 040220 (modified)
Oval Side Markers -- APC 40.2550.SM
White/Red Tailights -- Eurolite/Toucan 048320 (modified)
Amplified Roof Antenna -- Fuba (BetaFlex D)
In Car Entertainment -- Call!!!
Redline Water Wetter used in the radiator coolant (changed every spring)
Mobil1 5w30 used in the Tranny (changed every spring)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi »</TD></TR><TR><TD CLASS="quote">bump for a clean 4th Gen
BTW where did you get those tail lights? I thought they're only made to fit the 92-93 models?</TD></TR></TABLE>
these puppies are a creation from my own garage... I took a set of clear tails for '90-'91 Accord from Eurolite/Toucan Industries and candied the brake/parking light section... I used VHT Metal Anodizing Red Paint Candy.
I've seen actual clear/red tails on E-bay before though...
