4 SALE: 90 Accord EX (CHECK OUT PICS!) ONTARIO, CANADA
Old Sep 18, 2003 | 02:18 PM
drives_a_honda's Avatar
Default 4 SALE: 90 Accord EX (CHECK OUT PICS!) ONTARIO, CANADA
ok,
so some of you already know, it has come to the point where I have to move on... Keep it short and simple, my car is 4 SALE!
I had it originally advertised in the AutoTrader with asking price of $7900.00 O.B.O.
I need to sell it (new car coming) so effectively I have renewed the ad with lower price, I'm flexible on pricing and this car HAS TO GO!!!
Some TAC members know the car more than others, but here are the essentials:
-e-tested/certified (ready to go)
-just aligned, 2 new tires, new brake pads and shoes
-269,000km (good chunk of it put on in my hands)
-WW Big Mouth II with shaved mouldings on the car
-freshly repainted
-two sets of rims/tires
-full suspension (struts/springs/camber kits/swaybar/tie bars)
-exhaust/CAI/headers
-usual bolt on stuff
-heavy duty clutch/lightened flywheel/EX-R tranny
-projectors/clear-red tails
-indiglo gauges and autometer 'phantom' A/F and oil pressure
I have pics/receipts, serious inquiries will be treated in a serious matter!
I'm asking $6900.00 O.B.O. (CDN$, will negotiate)
check out my website for more pics/details on the car!
http://www.angelfire.com/ny/1984HondaAccord/
Old Sep 18, 2003 | 02:34 PM
Default VIN#
I forgot, the car has 269,000km (167,000 mi) and I will include a spare F22A3 motor with proper paperwork.
VIN# JHMCB7557LC814669
Old Sep 19, 2003 | 05:53 PM
Default modifications...
I have receipts for most everything along with normal maintaince items (oil changes, rad flush, etc, etc).
Dynoed (before the EX-R header, lightened flywheel, clutch) @:
113.7hp@4900rpm(at the wheels)
135.3ft-lb@3900rpm(at the wheels)
The car has shaved side mouldings and rear bumper moulding (very unique) and it was repainted this past July... below is the list of all the mods...
Front Bumper -- WingsWest 890428 (Big Mouth II)
17" Wheels -- ADR N/A (DTM)
215/45ZR17 Tires -- Kuhmo N/A (Ecsta Supra 712)
Cross Drilled Rotors -- Ractive 320770 (Left) 320870 (Right)
High Friction Brake Pads -- AEM 26-115 (Nissin Calipers)
Lowering Springs -- NEUSPEED 55.20.11 (Sport)
Gas Struts Tokico -- HU3714 (HP Front) HU2781 (HP Rear)
Adjustable Front Camber Kits -- Ingalls 3572
Front Lower Ball Joints -- McQuay-Norris (just installed)
Front Upper Ball Joints -- Honda O.E.M. (just installed)
Outer Tie-Rod Ends -- Honda O.E.M. (just installed)
Rear Upper Ball Joints -- McQuay-Norris (just installed)
Front Upper Tie-bar -- Ractive H-041/1
Rear Upper Tie-bar -- Ractive H-042/1
Rear Lower Tie-bar -- OBX-R OBTX-H1005A
Rear Sway Bar (13/16") -- Suspension Techniques 51120
Polyurathane Front Sway Bar Links -- Energy Suspension 16.8105.R (Red)
Polyurathane Front Engine Mount Insert -- Energy Suspension 16.1107R (Red)
Cold Air Intake -- Ractive 22265 (Silver)
Hi Flow Air Filter -- K&N RU-3570
Bypass Valve -- AEM 20-401S
4-2-1 EX-R Header -- Honda O.E.M.
O2 Sensor (EX) -- NGK
2&1/4" Hi-Flow Cat -- Carsound
2&1/4" Hi-Flow Resonator
2&1/4" Rear Muffler -- Ractive MT-228
9mm Ignition Wires -- Ractive
Radiator/Braided Hoses (1 year old)
'90 EX-R Transmission -- Honda O.E.M.
Lightened Flywheel -- RAM Cylinder Heads Machine Shop N/A (custom machined O.E. part)
Clutch -- RhinoPac HD
Short-Throw Shifter -- NEUSPEED 66.20.34
Indiglo Gauge Faces (km/h) -- Ractive EL-605
Air/Fuel Ratio Gauge -- Autometer 5775 ('Phantom')
Oil Pressure Gauge -- Autometer 5727 ('Phantom')
A-Pillar Dual 2&1/16" Gauge Pod -- Gauge Works by AutoMeter 20112 ('94-'01 Acura Integra Pod--Tan)
Deep Cycle Battery -- Optima D38/78 8012-021 (Yellow Top)
Projector Headlights -- APC 40.3523.HL
'Euro' Corners -- APC 40.3060.CLE
Smoked Bumper Lenses -- Eurolite/Toucan 040220 (modified)
Oval Side Markers -- APC 40.2550.SM
White/Red Tailights -- Eurolite/Toucan 048320 (modified)
Amplified Roof Antenna -- Fuba (BetaFlex D)
In Car Entertainment -- Call!!!
Redline Water Wetter used in the radiator coolant (changed every spring)
Mobil1 5w30 used in the Tranny (changed every spring)
Superdragr45
Aug 2, 2003 03:54 PM
eccentric.ek
Jul 6, 2003 05:12 PM
Accords 4U2 NV
Mar 21, 2002 04:11 PM
