Should I blueprint my injectors?
Old Sep 18, 2003 | 12:08 PM
nmhybridog's Avatar
Default Should I blueprint my injectors?
Building a honda challenge car..... My motor is a first gen B16 from 1990. Would it be wise to blueprint 13 year old injectors? I don't have any knowledge in this area... and since I've spent a chunk of money (for me at least) on this... I don't want to bottleneck the motor anywhere... Do injectors "gum up" after sitting for a few years..... Help me out here guys. Basically, is it worth the 400 bucks?
Old Sep 18, 2003 | 01:13 PM
clockworks's Avatar
Default Re: Should I blueprint my injectors? (nmhybridog)
hell no, it's not worth 400 bucks! Yes, if the injectors SIT with gas in them for a few years, they will gum, but not if they have been run over the past few years. I would say go to a cheap junkyard and get a whole bunch. Then make yourself/buy a fuel metering tester. Clean out all the injectors, then measure the flow rate of all of them. Pick the four that are closest to each other.
Old Sep 18, 2003 | 01:19 PM
HONDABROMANDUDE's Avatar
Default Re: Should I blueprint my injectors? (clockworks)
Doesn't RC do it for about $90? if they do, and Im pretty sure they do, you might as well.
Old Sep 18, 2003 | 01:55 PM
nmhybridog's Avatar
Default Re: Should I blueprint my injectors? (itec311)
Isn't it 90 per injector though?
Old Sep 18, 2003 | 03:12 PM
ZigenBallz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nmhybridog &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it 90 per injector though?</TD></TR></TABLE>
Nope it's like $10-20 per injector...
Old Sep 19, 2003 | 03:03 PM
Mr Hammond's Avatar
a/k/a Jomo
$400? Good god brand new RC's are cheaper then that! . You should do everythign the Honda Challange rules alow. Every little bit helps. RC does it for about 1/4 that.
h22bb1
Oct 21, 2008 08:42 PM
92civicx
Aug 17, 2007 04:02 PM
Project-D
Oct 12, 2006 04:19 AM
arw321
Jan 8, 2005 03:29 PM
