B16 mounts
Old Sep 18, 2003 | 11:35 AM
solman74's Avatar
Default B16 mounts
Ok, I need to real good input here. I ordered the Hasport mounts. I got the shifting linkage and all 3 mounts. I also ordered the rear mount but it didnt' show up. I used the stock one and I have an unusual amount of engine play. Did you all remove the front mount? My motor keeps flexing and hitting that damn mount. But I Mic'd 1mm of space between the motor and the mount maybe 2mm at the most. Got any suggestions. Can I get some references on what you all did?
Old Sep 18, 2003 | 11:36 AM
Malgerus's Avatar
Default Re: B16 mounts (solman74)
I just left it. My mounts seem stiff enough that I don't have any contact with that front bracket. Still, grind it off if you can and don't worry about it.
Old Sep 18, 2003 | 11:40 AM
civickiller's Avatar
Default Re: B16 mounts (Mr. S)
i cut my front mount off, but im not using hasport mounts
Old Sep 18, 2003 | 11:58 AM
Phatwhippin_CRX's Avatar
Default Re: B16 mounts (civickiller)
almost everyone with a hasport kit cuts it off, you're supposed to.
Old Sep 21, 2003 | 11:52 AM
JDMHatch101's Avatar
THE HASPORT KIT TELLS YOU TO CUT THAT MOUNT OUT. IF YOU USED ONE OF YOUR STOCK MOUNTS NO WOUNDER YOUVE GOT ENGINE PLAY. AFTERMARKET MOUNTS ARE URETHANE.
acmoc
Mar 29, 2017 05:36 PM
Nova_Dust
Mar 14, 2008 04:40 PM
strictly.business
May 2, 2006 11:40 PM
dso
Dec 2, 2004 05:15 PM
