ouch, look at my stock axle
Old Sep 18, 2003 | 11:29 AM
austrian type-R's Avatar
Default ouch, look at my stock axle
This is an oem ITR axle got damaged by using slicks and crazy 375whp on the circuit. Yeah, I hope my DSS stage 2 will do better
Old Sep 18, 2003 | 12:22 PM
Cal's Avatar
Cal
Default Re: ouch, look at my stock axle (austrian type-R)
I did that with my old B16A axles. Twice
Sucks nuts, good thing its an easy replacement and short install time
Old Sep 18, 2003 | 02:35 PM
GM2000ITR's Avatar
New User
It could be worse:
Old Sep 18, 2003 | 03:01 PM
CW-ITR's Avatar
Any body has SSS stage 1 axles and do they hold up better than the stocks?
Old Sep 18, 2003 | 04:28 PM
Big Phat R's Avatar
375 whp and you're surprised??
I can't imagine the stuff you would be breaking if you drag raced your car!
Old Sep 18, 2003 | 06:29 PM
TodaSi's Avatar
Default Re: ouch, look at my stock axle (Big Phat R)
I was expecting to see some mean damage
If you have a problem with the DSS axles get the Gators
https://honda-tech.com/zerothread?id=580090
Old Sep 18, 2003 | 06:40 PM
STEALTHMODECOUPE's Avatar
Default Re: ouch, look at my stock axle (TodaSi)
my axle is stuck on the rotor..the splines are like intertwined with each other
adaM
Old Sep 18, 2003 | 06:47 PM
ZygSpeed's Avatar
Default Re: ouch, look at my stock axle (STEALTHMODECOUPE)
I switched to the JDM 36 mm axles, now I have to figure out how to get my ABS sensors on the JDM knuckles close enough to the sensor rings for the ABS to work.
Old Sep 18, 2003 | 07:13 PM
LSTEG96's Avatar
better to have the axels break than to have it tear somethin out in the tranny imo!!
Old Sep 18, 2003 | 07:14 PM
b19coupe's Avatar
At least you could drive it home. A little noisy perhaps
Old Sep 18, 2003 | 07:19 PM
EK MONEY's Avatar
Default Re: ouch, look at my stock axle (GM2000ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GM2000ITR &raquo;</TD></TR><TR><TD CLASS="quote">It could be worse:
LMAO about your sig. its true
Old Sep 18, 2003 | 08:10 PM
twentywontowin's Avatar
Default Re: ouch, look at my stock axle (Peagreenhatch)
Man, that's nothing. On my old DSM, I had to replace an axle, and after getting in there I find out that I need to replace the axle and the wheel bearing because they were seized together.
Still though, nice damage. I saw your video's and you have one awesome R.
Old Sep 18, 2003 | 09:42 PM
this axle in the pic is an oem ITR axle. I have no probs with DSS now.
JDM97R
Sep 26, 2010 03:05 PM
CustomX113
Dec 20, 2006 10:21 AM
teler86
Sep 9, 2005 09:55 AM
Michael Delaney
Jun 21, 2001 06:38 AM
