Cheap Power
you advance the timing by turning the dist a certain amount thus advancing how much the spark will ignite before TDC in doing this you must use premium gasoline to avoid pinging or detonation.
the TB coolant bypass is rerouting the coolant line that flows under the TB into the FIV by removing the FIV and feeding the coolant line to the IAC. in my opinion the FIV only serves a purpose if you live way up north and plan to park your car in -15 or colder weather thus your tb can freeze
whats tdc on the timming advance note... um i smell gass fumes in my car dammit there no catalic conerter on my eahcust dam stright pipe acccord sounds like a muscle car but anyhow i was wondering if anyone can suggest anything for my honda 90 accord with 95 motor as far as ignition.. canii install a exterior coil for better sparks or does anyone have a better idea..c uase my coil is internal thanks doe any eplys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crafty »</TD></TR><TR><TD CLASS="quote">you could also remove the seats/carpet/interior/door panels....
then you wouldnt have to spend a dime!</TD></TR></TABLE>
gets my seal of approval! i like this guys thinking!
weight reduction, free mods (some already listed), also nitrous if you want real power.....i/h/e is a joke I see it more as finishing touches anymore....not really a place to build power, just to "polish" existing power.
- Nathan
- Nathan
remove your power steering
take out extra weight
I run advanced timing because of the throttle response, not sure if it adds power.
Did I mentin weight reduction?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2awagon »</TD></TR><TR><TD CLASS="quote">run higher octane gas</TD></TR></TABLE>
hahahahaha..it wont do **** yo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord »</TD></TR><TR><TD CLASS="quote">advance the timing
TB coolant bypass
how would you go about advancing the timing
and whats TB coolant bypass?</TD></TR></TABLE>
on the throttle body assembly, there's a coolant line run though the entire throttle body to warm up the tb but it would also heat up the tb(heat is your enemy, most of the time)
TB coolant bypass
