Clutch pedal feels weird at times
I just put a new clutch in a few months ago. It felt great until we pulled the motor and when we put the engine and tranny back in is when it started acting weird. It doesent happen all the time its only every once in awhile. Sometimes when I go to press the clutch in it feels really spongy like there is air or something in the lines. When we reintalled the tranny backin the car we did bleed all the air out or at least I thought we did. Like I said it doesent do it all that often. Do you think that there could be air in the lines still or what. I was thinking that if there were air in the lines it would do it all the time. Oh yeah the tranny is a B16 hydro tranny and the clutch is a clutch specialties 6 puck clutch.
I havent tried to bleed the lines again since the install yet to actually see if there is any air in the lines. I just thought that I would make a post before I go and start working on it because it could be soomething else. Thanks Guys.
You should try to bleed it before you go with anything else.....9 out of 10 times that fixes the problem. Sometimes air just gets trapped further up there and needs a good bleeding.
93SiHB
Oct 2, 2005 10:00 AM
