Reaching the Limit of my Suspensions. H&R/Koni to GC/Koni ?
Old Sep 17, 2003 | 09:54 PM
Understeer's Avatar
Default Reaching the Limit of my Suspensions. H&R/Koni to GC/Koni ?
I am currently running
-H&R Sport Springs
-Koni Yellows
-ITR 22mm Rear Swaybar
-4 Point Neuspeed Strut Bar
-Falken Azenis Tires
-Other chassis stiffening bars
I know the limits of my car and the suspension from auto-x, and I want something that will handle better. I was thinking of following the Ground Control and Koni Yellow route, since I already have the Koni's. Will the Ground Control's increase the limit by a lot?
What characteristics did owners of H&R/Koni see when you changed to GC/Koni?
What spring rates would you recommend? I was thinking 400F/500R, but will that cause too much rotation? Is the read bearable on the streets? I don't mind a stiff suspension, but what do you guys think?
I have rode in a EK Civic with Spoon Show 16KF and 14K rear, and I thought it would be really really bad on the streets, but it turned out to be quite bearable.
I don't know, what do you guys think?
Old Sep 17, 2003 | 10:05 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Reaching the Limit of my Suspensions. H&R/Koni to GC/Koni ? (Understeer)
Holy crap that's almost 900lb/in in front and 800 in back!
500 is pushing the limit of what the OTS Konis can handle. I plan on going with 350F/400R.
I rode in my friend's EK w/ Konis and GC 450F/350R and it seemed fine, but I really can't compare until I can drive my car and then his car back to back on some really rough roads, which is pretty much ever road where I live.
Old Sep 18, 2003 | 08:52 AM
Understeer's Avatar
Default Re: Reaching the Limit of my Suspensions. H&R/Koni to GC/Koni ? (PatrickGSR94)
Yeah, superstiff and sometimes bouncey.
Old Sep 18, 2003 | 11:12 AM
ingrate's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer &raquo;</TD></TR><TR><TD CLASS="quote">
The car is much less likely to understeer at the limit. The car feels much more balanced than with the H&R's. I wouldn't go past 450 to 500 lb/in for the spring rate. My Tein S'tech springs were somewhere in that vicinity and i don't think the OTS konis handled it too well. Just remember the rear rate will affect the ride quality more than the fronts will so choose wisely. Or you could buy another set of rear springs with different rates.
Old Sep 18, 2003 | 03:31 PM
juniordc2's Avatar
Default Re: Reaching the Limit of my Suspensions. H&R/Koni to GC/Koni ? (ingrate)
OTS Koni Yellows can handle a MAX of 400lbs/in a Koni representative told me.., any higher than that and your exceeding its efficency and lowering the life of the shock.
Old Sep 18, 2003 | 06:17 PM
Tweakmeister's Avatar
I love my 400/500 setup with ITR rear swybar (22mm).
The 23mm rearsway came in today.
One of the most important factors of the equation is tires. The Yokohama ES100's come highly recommended from me for their grip.
As for the ride. I have the Yellows on nearly full stiff. It's a little bouncy, but then again the roads here aren't exactly smooth pavement all the time. Several passengers have mentioned "getting air" off some of the bumps in the road
Old Sep 18, 2003 | 06:21 PM
Understeer's Avatar
Default Re: Reaching the Limit of my Suspensions. H&R/Koni to GC/Koni ? (Tweakmeister)
Okay that brings up another crtical issue.
Why do some go for rear heavy spring rates. IE: 400/500 vs front heavy 500/400 spring rates? Which one is better in a sense?
Old Sep 18, 2003 | 06:39 PM
that's a great question, there really is no answer for everyone. it depends on what you're trying to achieve.
Personally:
I like the 400/500 setup. I like oversteer/rotation/throttle lift control. I also like a good ride! For these reasons I recommend the 400/500 setup based upon first hand aggressive driving experience.
All this being said it's the tires that really make the difference once this setup is in place.
Old Sep 19, 2003 | 04:19 AM
EnjoyTheRideDC2's Avatar
First off, if you get GC's, you have to buy a new set of Koni's...Koni makes a special body to mate with the GC. I would check Ground Control's site and look at the footnotes about running Koni's with their coilovers. Stick with springs/Koni.
Old Sep 19, 2003 | 04:51 AM
Community Builder
Default Re: Reaching the Limit of my Suspensions. H&R/Koni to GC/Koni ? (EnjoyTheRideDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">First off, if you get GC's, you have to buy a new set of Koni's...Koni makes a special body to mate with the GC. I would check Ground Control's site and look at the footnotes about running Koni's with their coilovers. Stick with springs/Koni. </TD></TR></TABLE>
no, you buy GC's with adapters that go on Konis.
I know because my friend just replaced his H&R Sports w/ GC sleeves for Konis.
Old Sep 24, 2003 | 05:34 AM
the GC's have a black insert on the inside that mates to the Koni snap-ring already on the shock body.
just to update a bit...with the more aggressive front pads I can now really make the rear rotate when braking
MugenEg
Suspension & Brakes
12
Nov 22, 2010 12:08 AM
integra-boy
Apr 11, 2007 03:35 AM
koczeka
Jan 29, 2007 12:41 AM
travisallenn
Suspension & Brakes
Nov 30, 2006 04:55 PM
PiXeL
Suspension & Brakes
Dec 18, 2005 09:40 PM
