Questions for rebuilding block
Old Aug 22, 2001 | 12:10 PM
Darren94ls's Avatar
New User
Default Questions for rebuilding block
wussup everyone?
i have a 94 ls with 124,000 miles and im going ls/vtec. i have a 00' si head and i was wondering what i have to do to rebuild my motor so its practically brand new and reliable.
the parts im planning or ordering are:
-itr pistons w/ring and pins
-ls rod bearings
-gsr oil pump, water pump, timing belt
-ls distributor
-gsr or itr tranny and new clutch
is there any other things that i should replace?
thanks
darren206
Old Aug 22, 2001 | 01:52 PM
EVOCELICA's Avatar
New User
Default Re: Questions for rebuilding block (Darren94ls)
If you use the LS distributor you will have to grind off one of the ears so it will fit the vtec head.
Old Aug 22, 2001 | 01:58 PM
HX_Guy's Avatar
Default Re: Questions for rebuilding block (EVOCELICA)
Throw some new Eagle rods and a crank girdle in there while everything is out.
Aftermarket rods are a must (along with ARP rod bolts) and a girdle is good insurance so there is less chance of spinning the bearings.
Old Aug 22, 2001 | 03:34 PM
keithv's Avatar
Also, get new main journal bearings as well.
I would replace the front and rear main seals, and increase the flow of the oil pump (as seen on the Endyn site).
Old Aug 22, 2001 | 10:19 PM
Darren94ls's Avatar
New User
EVOCELICA i dont know much about engines but the shop thats going to be working on my car said to use the ls distributor but u said diffrently. how do u know that it wont fit perfectly?
anyone know through experience?
and thanks for everyones help
darren206
gsrturboEK
Northern California (Sales)
Jul 16, 2009 03:39 PM
ieatrice
Jun 4, 2008 08:12 AM
migs
10
Jul 15, 2005 07:40 PM
j87w
Feb 9, 2005 10:07 PM
lsvtec101
14
Mar 21, 2004 09:28 PM
