anaerobic sealant?.....d16y8 rocker arm assembly
Old Sep 17, 2003 | 07:28 PM
5thgen's Avatar
Default anaerobic sealant?.....d16y8 rocker arm assembly
what is a this kind of sealant?....is it another word for hondabond?
Because this manual (haynes) says to use it on caps 1 and 6.....basically the outer caps. Do I just use hondabond?, or does someone know what kind of sealant to use?
thanks
Old Sep 17, 2003 | 10:51 PM
BuddhaSiR's Avatar
Default Re: anaerobic sealant?.....d16y8 rocker arm assembly (5thgen)
RTV silicone.
Old Sep 18, 2003 | 04:39 AM
JimBlake's Avatar
Default Re: anaerobic sealant?.....d16y8 rocker arm assembly (BuddhaSiR)
Anaerobic sealant won't harden until it's deprived of air. So any stuff that oozes out of the joint won't harden. Loctite is like that.
Other than that particular feature, it's kinda like RTV or other similar stuff. Is HondaBond anaerobic? (I don't know.)
Old Sep 18, 2003 | 08:40 AM
axhandler's Avatar
Default Re: anaerobic sealant?.....d16y8 rocker arm assembly (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Is HondaBond anaerobic? (I don't know.)
Hondabond is RTV sealant...they are the same...there is a thread about this somewhere...most people use permatex grey.
Old Sep 18, 2003 | 09:40 PM
5thgen's Avatar
Default Re: anaerobic sealant?.....d16y8 rocker arm assembly (axhandler)
cool.....i just went out and got some hondabond today.....works out good
Old Sep 19, 2003 | 05:29 AM
axhandler's Avatar
Why did you pull the rocker arm assembly...are you installing a cam? I just went through that...
Old Sep 19, 2003 | 05:39 PM
5thgen's Avatar
we pulled everything apar....valves, springs, everything but the valve guides to clean everything...so far its looking good.
Old Sep 22, 2003 | 07:01 AM
axhandler's Avatar
Wow...lot of work. Your not replacing anything, just checking it all out? I wish I had a spare head to do that to.
msinsky14
Paint and Body
Aug 29, 2007 11:50 AM
EngineNoO9
Honda Motorcycles
19
Jun 3, 2007 07:15 AM
NickW
11
Nov 16, 2004 10:44 PM
130R
Aug 18, 2004 12:57 AM
youngkow
Jun 25, 2003 11:55 PM
