injectors with OBD1 in EF
Are there any problems with using OBD0 injectors with resistor box or is it better to convert to OBD1 injectors w/o box.
Just wondering if these options give same impedance.
Thanks
Thanks
I run OBD0 injectors w/ resistor box with my p28 OBDI ECU. No Probs whatsoever, both types of injectors have the same flow rate so I don't see why it would be beneficial either way. I guess what may be important is that you have a fully matched set of injectors delivering an even spray to all four cylinders.... I've been thinkin about getting mine balanced/blueprinted for a while now...
da9blk1
Oct 1, 2012 02:00 PM
