Weird oil leak after valve adjustment...
Old Sep 17, 2003 | 12:15 PM
jdmspoonitr's Avatar
Default Weird oil leak after valve adjustment...
Well about 1200 miles ago I got a valve adjustment. Being the dumbass that I am....I did not realize that I would need other parts like gaskets to successfully complete the job.
We went ahead and did the valve adjustment anyway.....and now I have a leak of oil...about 1 qt. in 1000 miles. Using Redline 10W-30. It is leaking off of the back of the valve cover...the side that faces the firewall. It looks like it dripped from my oil cap and went onto the valve cover.
The weird thing is how come there is only oil on the valve cover and not anything else???
How would not replacing the gasket make it leak from the oil cap area?
Looks like I need to redo it this weekend. Does anyone have the part #'s for all the stuff that I need to replace when taking off the valve cover?
And even after the valve adjustment there has been a loud tick coming from the bottom of the dngine bay....I'm pretty sure it's not the injectors. The noise is audible from inside the car, especially when idling or driving next to other cars. The tick speeds up with the revs. Kind of like tapping an aluminum can sound.
Old Sep 17, 2003 | 12:22 PM
CPR's Avatar
CPR
Default Re: Weird oil leak after valve adjustment... (jdmspoonitr)
Make sure the rubber seal on your oil cap is still there. There have been a couple times where I've removed the oil cap only to have the seal separate and stay on the valve cover.
Old Sep 17, 2003 | 12:24 PM
Default Re: Weird oil leak after valve adjustment... (CPR)
hmmmm....i'll check that right now...thanks CPR!!!
Old Sep 17, 2003 | 12:39 PM
hmmmm....the rubber seal is still on the cap.
I also noticed that the rubber seal that is sandwiched between the head and the valve cover is moist with oil. The edge of the head is also moist with oil. Only in that one section near the fill hole though. Hmmmm...I was on it hard yesterday and I could smell the oil burning. Then I checked today and I'm almost a quart down.
Old Sep 17, 2003 | 12:43 PM
CPR's Avatar
CPR
How certain are you that it's coming from the oil cap? Did you check the condition of the oil cap seal?
I remember fuggin up my valve cover gasket while putting the valve cover on the head a while back. the problem became obvious instantly when i turned on the car. I suggest starting up your car and inspecting around the area where the cover meets the head and see if you see any leaks.
Old Sep 17, 2003 | 12:55 PM
not positive.....but I see moist oil marks on the valve cover leading from the fill hole to the back side of the cover where it meets the head.....right at that point you can see the wet look on the edge of the head.
Old Sep 17, 2003 | 01:02 PM
Cosworth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">
And even after the valve adjustment there has been a loud tick coming from the bottom of the dngine bay....I'm pretty sure it's not the injectors. The noise is audible from inside the car, especially when idling or driving next to other cars. The tick speeds up with the revs. Kind of like tapping an aluminum can sound.</TD></TR></TABLE>
Is this your first time doing a valve adjustment? If so, you might need to adjust the valve again, if there are ticking noises still. I know my first time around, I had to double & triple check the clearance. It took me a long time...
Old Sep 17, 2003 | 01:07 PM
Default Re: Weird oil leak after valve adjustment... (Cosworth)
Actually Chris on this board and Austin helped me do the adjustment. I'm positive that they did a good job. Would valve tick seem to come from the bottom of the car??
I'm really not sure what I'm supposed to be listening for. It's very loud, especially now with the silencer in.
Old Sep 17, 2003 | 02:46 PM
B2FiNiTY's Avatar
A tick near the bottom... is it your header?
Old Sep 17, 2003 | 02:49 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">I did not realize that I would need other parts like gaskets to successfully complete the job.</TD></TR></TABLE>
thats may be the problem.. replace with new seals..
Old Sep 17, 2003 | 02:50 PM
b19coupe's Avatar
If you pinched the valve cover gasket, it would explain the oil leak and the ticking. Seen it before.
Old Sep 17, 2003 | 02:51 PM
TypeR 599's Avatar
Default Re: Weird oil leak after valve adjustment... (B2FiNiTY)
could be your header making that ticking noise.
just change your valve cover gasket and apply hondabond to the new gasket and you'll be fine.
Old Sep 17, 2003 | 03:31 PM
Austin's Avatar
Default Re: Weird oil leak after valve adjustment... (TypeR 599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 599 &raquo;</TD></TR><TR><TD CLASS="quote">could be your header making that ticking noise.
just change your valve cover gasket and apply hondabond to the new gasket and you'll be fine. </TD></TR></TABLE>
We had to reuse the old gasket, hondabond used. It is entirely possible that the basket is pinched...but I wouldn't think so, but that would have been Chris(let's just blame him j/k)
Old Sep 17, 2003 | 04:22 PM
Rob Dizzle's Avatar
Default Re: Weird oil leak after valve adjustment... (Austin)
you can get a new oil cap gasket from honda if you need one
i had the same thing, but mine was just a wee bit older
also check your o-ring on the crank case breather box.
Old Sep 17, 2003 | 04:57 PM
ITR#132's Avatar
Ive been reusing my gaskets for the longest time without Hondabond. Most likely its either a pinched gasket, cam seals, OR the the valve cover was way over tightened.
Old Sep 17, 2003 | 05:09 PM
Tommy_Gunns's Avatar
I've re-used the current valve cover gasket on my ITR 3 times already with no leaks
curvenut
Jan 8, 2014 09:39 AM
kb58
Mar 24, 2011 10:38 AM
sevenfc
Dec 5, 2008 03:03 PM
casmello
Jan 23, 2006 05:32 PM
Layziebtnh055
Apr 11, 2004 07:41 AM
