Fuel Filter issue
Old Sep 17, 2003 | 10:27 AM
pleccese's Avatar
From: Port Jefferson Station, New York, United States
Default Fuel Filter issue
I was replacing the fuel filter on my '92 Civic. The old filter came off easy enough with some elbow grease, but the bolt/pipe that goes in horizontally does not want to thread into the new filter. I tried the old filter just to make sure I wasn't going crazy and now that's not threading! Help!!
Old Sep 17, 2003 | 12:23 PM
FourthGenHatch's Avatar
Default Re: Fuel Filter issue (pleccese)
You might have damaged the threads on that bolt. And/or its just a bastard bolts which requires it be perfectly lined up to thread in.
Also this is the wrong forum for a '92.
Old Sep 18, 2003 | 12:45 PM
pleccese's Avatar
Thanks on both counts. Which forum is correct?
Old Sep 18, 2003 | 02:35 PM
Project91CRX's Avatar
we can still help you here though, Did you check the bolt to see if there's any damaged teeth on it? Either you have to try to line it up to screw it in or you'll have to get a new bolt.
Old Sep 18, 2003 | 02:43 PM
pleccese's Avatar
Default Re: Fuel Filter issue (Project91CRX)
The bolt did not seem to be damaged, although I did spend an inordinate amount of time trying to make sure it was perfectly lined up to no avail (And I have tightened a few screws previously). Maybe it is damaged and I just can't see it. Would you know if that replacement bolt be available genrically or is that a Honda-specific part?
Nihsnek
17
Dec 30, 2011 02:40 PM
95lscivic
Apr 18, 2007 10:21 PM
Archxor
Nov 7, 2006 04:36 PM
SexyAzNMami
Nov 19, 2004 12:00 PM
michaelpr
Mar 16, 2002 12:18 PM
