Problem with my starter.....
Well as the topic states I have a problem with my car starting. When I try to start the car the starter does not turn over, no click, nothing. It only starts with the key sometimes. So I took my starter out and had it checked at checker and everything turned out fine. So I put the bastard back in and still nothing. So what I did is I got a screw driver and touched the 12v to the solinoid and it turned over(hot wired it). What do you guys think might be the problem? One more thing the car is a '89 crx si w/B16.
TIA
Modified by UNDER PRESSURE at 10:29 PM 9/17/2003
TIA
Sounds like your starter solinoid is messed up. Or your ignition switch, but since you said it started when you touched it with a screw driver then I would say its the starter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNDER PRESSURE »</TD></TR><TR><TD CLASS="quote">I think i'm just going to end up buying a hyper ground kit for the rex.</TD></TR></TABLE>
Waste of money, just make your own.
I had that problem a long time ago. A mechanic I had at the time fixed it with a chrysler part. I honestly do not know what it is (maybe a relay of some sort). Sorry.
The thing is I replaced the starter several times and it was always good. I still have it working with the box. I'm sure its a bad connection or a ground
Hope that helps
Hope that helps
EJ1 wilcox
Apr 25, 2005 02:25 PM
