GodSpeed Test Pipe
Old Aug 22, 2001 | 09:28 AM
01itr518's Avatar
New User
Default GodSpeed Test Pipe
Anybody get the test pipe from GodSpeed Motorsports for their JDM or DC 2.5" header?
I am considering getting this and want to know what your installation experiences were and if the check engine light really doesn't come on. Considering I have OBDIII, will my check engine light come on?
Old Aug 22, 2001 | 09:37 AM
S13Koop's Avatar
Default Re: GodSpeed Test Pipe (01itr518)
Read here
Here also
You are tiny grass hoppa!!
Old Aug 22, 2001 | 10:07 AM
Kengs's Avatar
Had mine for 6 mos. - no CEL
For the Si, the pipe is about 3/8-1/2 inch too long; dunno about the ITR.
Old Aug 22, 2001 | 10:09 AM
Yellow3TypeR's Avatar
Default Re: GodSpeed Test Pipe (kengs)
pipe is too long for ITR also
Old Aug 22, 2001 | 11:45 AM
VAtypeR00@work's Avatar
Banned
Default Re: GodSpeed Test Pipe (Yellow3TypeR)
Mine fit fine, had it about 7 months now.
Bryan
Old Aug 22, 2001 | 11:56 AM
Kilohead36's Avatar
Default Re: GodSpeed Test Pipe (VAtypeR00@work)
Mine fits good on JDM header..had it for almost a year now some guys had fitment problems..just wondering if mine will fit on a spoon header...
Old Aug 22, 2001 | 12:00 PM
Banned
Default Re: GodSpeed Test Pipe (Kilohead36)
Dan will have the final say so on fitment, but i would assume it would be fine
Bryan
Old Aug 22, 2001 | 12:02 PM
PMTypeR's Avatar
Mine din't fit either!
Old Aug 22, 2001 | 12:15 PM
Default Re: GodSpeed Test Pipe (PMTypeR)
the older test pipes fit fine, then Dan changed design/machine shops. They made the test pipes longer. That's why some fit fine and others don't.
Old Aug 22, 2001 | 12:42 PM
ITR-01-0977's Avatar
New User
Mine is too long also....going to get it cut down and have a new flange welded on so I can use it.
Old Aug 22, 2001 | 01:18 PM
onyx00's Avatar
Default Re: GodSpeed Test Pipe (ITR-01-0977)
Mine is too long however we were able to squeeze it in. Also, the bolt holes were drilled to the incorrect size; Ihad to make them bigger.
Old Aug 22, 2001 | 01:31 PM
RATEDR's Avatar
Default Re: GodSpeed Test Pipe (onyx00)
Mine fit fine as well...no CEL! I have the JDM 4-1 header.
However, The flanges up front dont mate well so you have to use skinny bolts to come in at an angle to bolt it up.
But the rear of it bolts up fine....I also had to extended the 02 Sensor wires so it would reach the bung. And buy a universal
2.5 inch gasket to put between the test pipe and the exhaust.
I think he has changed the design to fit better since I purchased mine though
Old Aug 22, 2001 | 03:15 PM
Jason's Avatar
Default Re: GodSpeed Test Pipe (RATEDR)
you would think if he was selling a product that it would at least fit...I wouldn't call that good customer service, but every one has their opinion
Tong.Y
Jan 2, 2011 08:14 AM
r1ch1e
Apr 4, 2006 10:27 AM
the soL that could
Mar 14, 2006 09:12 AM
lsvtec101
10
Nov 4, 2005 02:35 AM
stizzit
Aug 29, 2001 11:08 AM
