How To Differentiate between B18CR and B18C GSR?
Old Sep 16, 2003 | 10:55 PM
gamakichi77's Avatar
Default How To Differentiate between B18CR and B18C GSR?
Anybody here can teach me how to differentiate between B18CR and B18C GSR Blocks. I want to buy B18CR blocks for my B16A head applications. I don't want to be cheated by the seller. ANy picture for my good reference. Thanks.
Old Sep 16, 2003 | 11:09 PM
PyR01-0347's Avatar
Default Re: How To Differentiate between B18CR and B18C GSR? (acidburns_di)
Well you can tell if you look at the top of the piston. On a JDM GSR the piston it should read P72 and if it is a ITR piston it should read P73. http://www.ff-squad.com/pistons.htm
http://asia.vtec.net/beystock/honda/integrar/
Modified by PyR01-0347 at 8:22 AM 9/17/2003
Old Sep 16, 2003 | 11:42 PM
ECKOTYPER's Avatar
ALSO THE BLOCK IS CLEARLY STAMPED B18C1 OR B18C5 IF ITS A JDM MOTOR THEN LOOK AT THE PISTONS IF ITS P72 GSR P73 ITR, IF THERE AFTERMARKET AND A JDM BLOCK U MIGHT NOT BE ABLE TO TELL THE DIFFERENCE
Old Sep 16, 2003 | 11:58 PM
Default Re: How To Differentiate between B18CR and B18C GSR? (PyR01-0347)
How about head undismantle from the blocks. How can i see is it B18CR blocks? By the way, thanks for info on Pistons spec of B - Series blocks.
Old Sep 17, 2003 | 02:30 AM
Gerhard_001's Avatar
As the posts said above, USDM look at the block, JDM look at the pistons.
Modified by 9SpreludeH8 at 12:20 PM 9/18/2003
Old Sep 17, 2003 | 04:22 AM
Dead Puppy's Avatar
Default Re: How To Differentiate between B18CR and B18C GSR? (9SpreludeH8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9SpreludeH8 &raquo;</TD></TR><TR><TD CLASS="quote">B18C5 not B18CR. </TD></TR></TABLE>
.. Just so you know 9SpreludeH8 the JDM b18c(GSR) and the JDM b18c(Type-R) both are just b18c, unlike the USDM b18c1(GSR) and the B18c5(type-R)
95ITRJDM
Mar 8, 2010 02:30 PM
krazeenoy
May 17, 2008 09:05 PM
hndacord02
May 11, 2007 07:09 AM
c-townekhatch
Dec 11, 2006 05:46 PM
austrian type-R
Aug 14, 2003 07:00 AM
