What so different between getting a muffler and a catback?
Old Sep 16, 2003 | 10:02 PM
ptsiu's Avatar
Default What so different between getting a muffler and a catback?
as topic stated, please advice
Old Sep 16, 2003 | 10:08 PM
junya16's Avatar
Default Re: What so different between getting a muffler and a catback? (ptsiu)
don't get bigger cat back piping when you just buy a muffler
Old Sep 16, 2003 | 10:16 PM
mskibbz-T's Avatar
Default Re: What so different between getting a muffler and a catback? (junya16)
A muffler is what you see when standing behind the car, just the cylindrical shaped piece with the exhaust tip coming off of it. A catback exhaust is the exhaust piping from the catalytic converter back, including the muffler and sometimes a resonator.
Old Sep 16, 2003 | 10:18 PM
ptsiu's Avatar
Default Re: What so different between getting a muffler and a catback? (mskibbz-T)
that's one of the different. So what's the difference in performance?
Old Sep 16, 2003 | 10:33 PM
cougar10ag's Avatar
the piping you get with a cat-back usually has less bends, made to better specs and is biggger in diameter for increased flow. it also matches the muffler so you get the most out of it.
showtymers619's Avatar
* B A N N E D *
flow
Old Sep 16, 2003 | 10:37 PM
mskibbz-T's Avatar
Muffler = Rice, mainly only for looks and sound
Catback = For power, looks, and sound
Get a catback setup, or get a muffler and have a shop custom make a mandrel bent exhaust setup for you that is designed for your flow needs
Old Sep 16, 2003 | 10:45 PM
NuclearB18B's Avatar
don't forget that catbacks will usually have mandrel bent piping as opposed the the crush bent pipes from the factory. better flow...
Old Sep 17, 2003 | 12:43 AM
AEI's Avatar
AEI
Default Re: What so different between getting a muffler and a catback? (ha illuminato un)
If you intend to have a shop make the cat back piping for you keep in mind that very very very few shops actually have a mandrel pipe bender to work with and they'll be crush bending the piping. If you are cheap then go ahead and do whatever you gotta do but if you take pride in your car and plan to keep it for awhile and make other mods to it then save until you get enough for a cat-back exhaust. If you want to get a header and/or high flow cat later it would be a waste of money without a good cat-back setup.
tabmow
Dec 11, 2009 10:59 PM
GReddy_Civic
Jul 6, 2009 08:08 PM
bokals
Feb 12, 2007 04:40 PM
Slow
Mar 6, 2004 10:40 AM
OldSchoolHatch
13
Feb 17, 2003 09:00 AM
