Honda S2000 Honda S2000
Old Mar 25, 2015, 09:29 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
How often do you guys change your transmission fluid?
Old Sep 16, 2003 | 07:35 PM
Razor's Avatar
Default How often do you guys change your transmission fluid?
I have about 2600 miles and was wondering if changing out the fluid with fresh honda MTF would be a good idea. i want to change the fluid now in case there might be some metal shavings in there during the breakin process. all input is appreciated. if it matters, i dont drive my car hard at all(very fast/hard shifting,power shifting,etc...)
thanks
Old Sep 16, 2003 | 10:42 PM
Pacman
Guest
Posts: n/a
Default Re: How often do you guys change your transmission fluid? (Razor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">I have about 2600 miles and was wondering if changing out the fluid with fresh honda MTF would be a good idea. i want to change the fluid now in case there might be some metal shavings in there during the breakin process. all input is appreciated. if it matters, i dont drive my car hard at all(very fast/hard shifting,power shifting,etc...)
thanks</TD></TR></TABLE>
2y or 30,000 mile should do....
Old Sep 17, 2003 | 07:11 AM
CLOUT's Avatar
since your car is still about new i wouldnt change the tranny fluid till after about 10k-15k depending on driving habits. i changed my tranny fluid around 17k and the s2 needed it...grinds were more frequent and 5th and 6th gear were harder to get into.i do drive my car "spirited" sometimes...so it does matter.now i plan to change my tranny fluid with genuine honda mtf every other oil change...about every 6k miles. good luck
Old Sep 17, 2003 | 07:43 AM
oos2kfan
Guest
Posts: n/a
I would wait until after 5K then change tranny and diff. You can probably let the tranny go longer and it won't hurt anything, but like you said it might be a good idea just to get the "gunk" out. The diff on the other hand will most likely be pretty dirty (from most accounts I've heard and from my car).
Old Sep 17, 2003 | 04:52 PM
00MRSi's Avatar
Default Re: How often do you guys change your transmission fluid? (oos2kfan)
I believe Honda recommends changing the tranny fluid every 30k miles. Changing before that would probably be even better, especially if hard driven miles are accumulated. I would wait a little longer, say 10k miles before changing it..
Old Sep 17, 2003 | 09:13 PM
Razor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oos2kfan &raquo;</TD></TR><TR><TD CLASS="quote">I would wait until after 5K then change tranny and diff. You can probably let the tranny go longer and it won't hurt anything, but like you said it might be a good idea just to get the "gunk" out. The diff on the other hand will most likely be pretty dirty (from most accounts I've heard and from my car).</TD></TR></TABLE>
thanks for the great responses. btw i did change my differential fluid at 2k miles, lots of people recommend it on s2ki.com. and they were right, the fluid came out very thick and black, smelled pretty bad too(sulfuric). i am now using mobil 1 75w90 and the rearend seems "quieter" now than before. you guys should get this done ASAP if you haven't yet. we all know the differentail is the weakest link on the s2000, so its a good idea to give this part the extra attention it needs.
Old Sep 18, 2003 | 06:42 AM
jolt-tsp's Avatar
Thats for the heads up on the diff. I changed my brothers tranny fluid at 10k with GM Syncromesh, and it shifts like butter. The old tranny fluid was still in good shape though, and he drives crazy hard. I haven't changed mine yet, probably do it next oil change (I've put about 15k on mine since I got it).
Old Sep 18, 2003 | 07:36 AM
esoterEK..'s Avatar
Default Re: How often do you guys change your transmission fluid? (jolt-tsp)
i recommend these from GM:
https://honda-tech.com/zerothread?id=549469
Old Sep 18, 2003 | 09:31 AM
oos2kfan
Guest
Posts: n/a
Good choice of rearend fluids That's what I'm running as well and it works quite well...but isn't it a pain to change that? Seriously...they could've made it easier to get to the fill bolt.
Old Sep 18, 2003 | 11:37 AM
Razor's Avatar
Good choice of rearend fluids That's what I'm running as well and it works quite well...but isn't it a pain to change that? Seriously...they could've made it easier to get to the fill bolt.</TD></TR></TABLE>
well i work at a honda dealership and i had access to a lift. once you have the car on the lift, everything is much easier to do. for the fill bolt, i borrowed one of those oil pumps from a tech and it worked perfectly. i guess you can buy these pumps from a auto store for like 10-20 bucks. it has a hose that can be attached to the fill hole, its really easy if you have the right tools.
good luck.
ITRbroham's Avatar
shit post warrior
I changed the tranny fluid on my S2K at 15K miles and I used genuine Honda MTF. I've had the car for a year and five months. IMO, I wouldn't wait till the factory recomended 39K miles or 2 years if you daily drive the car
I didn't change the diff. fluid becuase I will be doing the 4.77 FD swap soon.
Old Sep 18, 2003 | 12:06 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: How often do you guys change your transmission fluid? (ITRbroham)
Wow, I guess I better do my tranny oil change soon, and my rear end change too... My car is over 2 years old and at 13k miles!!!
Old Sep 18, 2003 | 12:37 PM
oos2kfan
Guest
Posts: n/a
good luck.</TD></TR></TABLE>
Yeah the pump I used was a POS...I need to try to get a better pump for my next change
Old Sep 18, 2003 | 02:16 PM
pro1342's Avatar
30K
Tmilli55
Honda CR-V & Element
Sep 26, 2018 01:27 PM
dan_g
27
Oct 5, 2009 03:06 AM
H22CD
Apr 21, 2006 08:16 AM
TopNotchR
Sep 24, 2004 06:50 PM
Jon D
12
Jan 22, 2004 07:07 AM
