Question On CRX Headlights
Hi
i was wondering if anyone knew what i would need in order to use the 90-91 headlights ...
i have a 89 crx si .. and wanted to use the 90 - 91 headlights and corners .. cause they are a little dif ... the one on the 90-91 screws onto the headlight bracket and not the fender right ?
will just a new set of fenders do it ? or do i need more
any info would be great ... and any info on the easiest one piece headlights to put in and what i would need ....
thanx !!!
-V-
CRX 89 SI
thanx !!!
-V-
CRX 89 SI
you could get new fenders.
or you can replace the little grommets that hold the screws in your fenders to the ones on a 90-91. i did it the reverse way going from 90-91 light holders to 88-89 grommets, so im sure you can do it.
ah .. why did you go to the 88 -89 ? i thought on the 90 - 91 .. the corner connected to a bracket on the headlight making it closer to the headlight and leaving as little space possible between the corner and the headlight ..
just wondering ..
thanx!
just wondering ..
thanx!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vera »</TD></TR><TR><TD CLASS="quote">ah .. why did you go to the 88 -89 ? i thought on the 90 - 91 .. the corner connected to a bracket on the headlight making it closer to the headlight and leaving as little space possible between the corner and the headlight ..
just wondering ..
thanx!</TD></TR></TABLE>
only reason i went to 88-89 on my old 91 dx was because i had projectors that were made for an 88-89 rex. thus my corners wouldnt work. my little plan worked and the fitment looked fine.
just wondering ..
ah ok .. coo
i see ..
is it true about the corner connecting to the bracket or whatever on the headlight on the 90 -91 .. just want to make sure before i start buying things ..
thanx
i see ..
thanx
RanCRX
Jul 12, 2009 04:22 PM
sm00thk0zz
Sep 13, 2004 11:06 AM
