Type R Clutch Question
Old Sep 16, 2003 | 03:40 PM
Fuuma0083's Avatar
Default Type R Clutch Question
Ok i'm finally changing out my stock clutch in my 98 GSR and i was wonder about getting a Type R clutch. I've already called the dealers and from what i found:
1. disk and release bearing is the same
2. pressure plate & pilot bearing is different
Now the question is will a Type R pressure plate & pilot bearing fit in a GSR?
Old Sep 22, 2003 | 06:49 AM
Fuuma0083's Avatar
Default Re: Type R Clutch Question (Fuuma0083)
anyone?
Old Sep 22, 2003 | 06:54 AM
conesmasher's Avatar
yea, they are the same clutch in retrospect. It may be a little stiffer, maybe not due to the fact that it only made 1 more ft/lb from the factory.
Old Sep 22, 2003 | 06:56 AM
typer_801's Avatar
ITR pressure plate is about 15% firmer and the release bearing is different because the R has a different flywheel than the GS-R.
turbosivtec
Feb 8, 2009 02:26 PM
kayyanne78
Jun 28, 2005 06:30 PM
SOHC_Brian
May 23, 2004 05:15 PM
Loveless
Aug 6, 2003 09:01 PM
