92 prelude (swapping a h22a into) PROBLEMS W/ STARTING
1992 Prelude car with a JDM H22A swap. l have fuel to the rail but the car will not
start. But the car will start when it is being sprayed w/ eether.
so why am i not getting fuel past the rail? It seems like the injectors are not
opening at all.
opening at all.
do you have spark? do you have the right firing order? also what yea is your h22 motor? are you using stock injectors? 92-96 prelude Vtec and 92-96 non vtec are peak and hold injectors, and 97 and up prelude are saturated injectors. you might need a resiter box if you are using a saturated injectors in a peak and hold system. did you take your injecters out and look at them, they may just be dirty, and they will have a little filter in the top of each injecter. hope this helps good luck. Ray
Modified by luderone at 8:34 PM 9/22/2003
Guest
Posts: n/a
everything listed was already done............ great spark - wired correctly - great poressure to the fuel rail - has a resister box already built in..
NO FUEL WILL PASS THROUGH INJECTORS! (have been pulled and put the old ones back in and still no results)
*this is a jspec motor h22
bump
