Type R slick/wheel combos?...
Old Sep 16, 2003 | 12:00 PM
01ITR#700's Avatar
Default Type R slick/wheel combos?...
I know there are several Type R's here making some pretty good power. After a dyno-tuning session I hope to be making 400whp(I believe I'm at 350whp) right now. Anyway, I need to know if 8.5/26-15 M&H slicks will fit on a Type R with stock suspension? Will they rub etc? Should I go with 24.5's instead?
I will be running 15x7" Kosei K1's for whatever slicks I end up buying.
Thanks for any info.
Mark
Old Sep 16, 2003 | 04:51 PM
94gsr4dr's Avatar
Default Re: Type R slick/wheel combos?... (01ITR#700)
i would go with the 24's cause i don't think you will be making the power for 26's, and why not run 13's for more sidewall?
Old Sep 16, 2003 | 05:54 PM
01ITR#700's Avatar
Default Re: Type R slick/wheel combos?... (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">i would go with the 24's cause i don't think you will be making the power for 26's, and why not run 13's for more sidewall?</TD></TR></TABLE>
400whp isn't enough for 26's? And come on man, everybody knows that 13" wheels won't fit over ITR brakes.
Thanks.
Mark
Old Sep 16, 2003 | 06:16 PM
99blackcivicSi's Avatar
lenzos should fit they are spaced out, ITR brakes arn't that much bigger than Si brakes
also go with 24's or something along those lines you don't have enough power to turn that monster of a tire
Old Sep 17, 2003 | 08:15 PM
ITR#132's Avatar
Default Re: Type R slick/wheel combos?... (99blackcivicSi)
They better be spaced out to 15" or it aint gonna fit.
Old Sep 17, 2003 | 10:03 PM
ExospeedAMcrx's Avatar
Default Re: Type R slick/wheel combos?... (ITR#132)
Here's a 15x8 Bogart Drag On fly for the ITR lug pattern.
Wil
Old Sep 18, 2003 | 11:46 AM
MrBillyX's Avatar
You'll have to run 15's because of the brakes on a ITR.
I run 22x8r15's MT Slicks on Rota Sub-Zeros and they have no problem clearing.
...Although... the Bogarts Drag 15s are really nice and really light....hmmm
Canadian_EF
Nov 18, 2014 05:15 PM
totsie7944
Nov 5, 2009 10:31 PM
b18LS
May 30, 2008 05:22 PM
ITR.#1446
Dec 16, 2007 09:42 PM
5_Lug_B
Aug 21, 2007 08:47 AM
