Question for 92 accord owner
I'm trying to do a rotor swap for my friends 92 accord lx. Well I've done it on many cars but Im just wondering if any of you know that how the front rotor is held by? Is it by the two philips screws or is it machine press on? TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Lx »</TD></TR><TR><TD CLASS="quote">pressed on unfortunately. You'll have fun getting it off too, I'm sure.
- Nathan</TD></TR></TABLE>
Well someone email me and told me that he has a 91 accord and its only hold on by 4 bolts but you need to take the hub nut out and its not press on. So could someone else elaborate on this. TIA
the rotor is actually held on by four bolts in the back. I know this because i swaped my rotors with a friend of mine. It took me an hour befor i figured out that there were four bolts in the back. Good Luck!
both people are right the best way is to remove the axle nut and in the back there are bolts and after you remove them the whole bearring assembly will come out and you can change the rotor
or
you can just remove the axle nut and use a hub puller to pull the rotor off with out removing the whole bearring i would do the first option if i were doing it at home
or
ksbsr6gn
Mar 24, 2018 05:34 PM
e jay one
Jul 17, 2006 02:33 PM
SlowAssAccord
May 15, 2004 02:15 AM
