Differences between 95GSR head and 1st gen b16 heads??
Old Sep 16, 2003 | 09:58 AM
Forrest Gump 9's Avatar
Default Differences between 95GSR head and 1st gen b16 heads??
Like the title say, what's the differences between the 95 GSR head and 1st gen b16 heads? My situation right now is I'm building a LS/Vtec and I have two choices of the those two heads. What's a good choice for NA? and why? Thanks!!
Old Sep 16, 2003 | 10:01 AM
skribblah's Avatar
Default Re: Differences between 95GSR head and 1st gen b16 heads?? (PaintStripper)
its basically up to you, people say that the b16 head flows better. but the only real differance is that the GSR has no quench pads, making the combustion chamber sorta look like an octagon. the reason that i chose the b16 over gsr is the quench pads. if i rev high and the rod bolt strects a little, i will have a little more area for the piston to go. wiith the gsr head, the piston would just kiss then head and then its bye bye.
but basically its whatever you can get cheeper.
Old Sep 16, 2003 | 10:07 AM
Rocket's Avatar
Default Re: Differences between 95GSR head and 1st gen b16 heads?? (skribblah)
Do B16 with ITR Manifold and Edelbrock TB.
Old Sep 16, 2003 | 10:52 AM
Default Re: Differences between 95GSR head and 1st gen b16 heads?? (Rocket)
If I was to put the GSR head on a 96LS block, what kind of CR would that yeild to? How about the b16?
Old Sep 16, 2003 | 11:08 AM
Rocket's Avatar
You should replace your LS pistons with BVTEC pistons since you're liable to have vavle-to-piston clearance problems if you run mildly big cams.
RaysBadAssEG
Jul 22, 2012 05:53 PM
SLURS
May 9, 2010 01:20 PM
slikwilly
Jun 13, 2008 05:34 PM
Spectrum24x
Feb 10, 2005 06:50 PM
Malice
Mar 6, 2002 07:29 PM
