B18A1 (LS) in 90 SI HB????
Old Sep 16, 2003 | 06:42 AM
tpr's Avatar
tpr
Default B18A1 (LS) in 90 SI HB????
Can this swap happen and what is needed? I have just come across both for a good deal can they work together? Are their balance issues with the 1.8L what abot transmission and motor mounts? I have done a ZC swap so I have some experience?
Shopping list??
What is the HP, Torque advantages over the ZC
Old Sep 16, 2003 | 06:52 AM
turboZChatch's Avatar
Default Re: B18A1 (LS) in 90 SI HB???? (tpr)
Yes it can be done you can use the ls tranny (cable) or you can buy a b16 tranny you need to get b-series mounts, shift linkage,axles computer and the harness if you can't modify your own the ls motor will be a noticable differance over your zc I think it is 140 hp correct me if im wrong someone
Old Sep 16, 2003 | 06:55 AM
bossman032's Avatar
Default Re: B18A1 (turboZChatch)
yes the b18b OBD1 is 140HP.
OBD0= 130HP.
LS has Torque!!!
Old Sep 16, 2003 | 08:30 AM
tpr's Avatar
tpr
I was hoping to hear first hand from someone who has this setup and if it is "nose heavy". Yes I want the torque but I do not want to compromise handling. I just love the quick balanced feel that i have achieved and want to keep it in tact.
Old Sep 16, 2003 | 08:59 AM
EF_LSVtec's Avatar
Default Re: B18A1 (tpr)
I've had this set up before and when you're doing a swap like this, of course, the B series motor is heavier than your old D so a bit of a compromise is expected. Nothing that a good suspension upgrade can't handle. If you're really particular about the balance, get your car corner-weighed after your swap that should help a lot.
Old Sep 16, 2003 | 09:41 AM
Importracin43's Avatar
I also suggest going with a b16 tranny. the longer gears in the ls make for compromised acceleration whereas the b16 has shorter gears and is better for it. torque + short gears = better acceleration= better qm times. i had a b16 tranny in my old integra and there was a world of difference.
then i got smart and bought my third ef si. SO HAPPY
Old Sep 16, 2003 | 06:11 PM
StorminMatt's Avatar
Default Re: B18A1 (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">LS has Torque!!! </TD></TR></TABLE>
Gee, that's news to me! Why didn't I feel it when I had an LS motor?
Old Sep 16, 2003 | 09:40 PM
sleeper4dr's Avatar
Default Re: B18A1 (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
Gee, that's news to me! Why didn't I feel it when I had an LS motor?</TD></TR></TABLE>
was it actually installed in a car?
my ls/vtec has decent torque with my full enterior (and then some) 89 4dr. wish i had a 84+ mm bore but the LS isnt too shabby.
SomeDude56
Sep 30, 2005 08:19 AM
russian_racer
May 25, 2003 08:29 PM
GlowingRotorsXSI
50
Jan 24, 2003 05:28 PM
hfracer420
Feb 17, 2002 05:36 AM
balistic CRX
11
Feb 15, 2002 09:28 AM
