NEED HELP ASAP --- 2GEN ACURA WITH 2000 TYPE R
JUST GOT DONE SWAPPING MOTORS BETWEEN A 91 ACURA B18B AND REPLACED IT WITH A 2000 ACURA TYPE R. PRETTY MUCH EVERYTHING BOLTS UP. THE ONLY PROBLEM I'M HAVING RIGHT NOW IS THAT IT'S NOT GETTING ANY FUEL. CHECK EVERYTHING, FUSES, FUEL PUMP, GROUNDS, INJECTORS, ALL GOOD. THIS IS WHAT I THINK THE PROBLEM IS -- SINCE 91 HAD A MESSED UP FUEL SYSTEM, THEY HAD A PURGE SOLENOID/ FUEL REG CUT-OFF SOLENOID- THATS WHY IT WONT RUN. CAN ANYBODY OUTHERE HELP!!!
0evilEMPIRE0
Sep 21, 2003 10:47 AM
