2nd Gen Acura
Old Sep 15, 2003 | 10:11 PM
SohcPower93's Avatar
Default 2nd Gen Acura
Hi, my car got totalled last week and now im looking for a replacement but i dont have too much money to spend so i just found a rolling chassis of a 1992 integra hatchback and i was wondering if the motor of my 1990 acura integra 4 dr will fit on that car, cuz if it does i think thats the cheapest way to go.
Thanks
Old Sep 15, 2003 | 10:23 PM
B2FiNiTY's Avatar
Default Re: 2nd Gen Acura (SohcPower93)
Yes it will.
Old Sep 15, 2003 | 10:25 PM
thaiphob's Avatar
Nikon!!!
they use the same motor.
Old Sep 15, 2003 | 11:00 PM
Newman's Avatar
New User
Same motor, different electronics. The 92 Integra will be using OBD-1 components and electronics so you'll need to use the components (ECU, distributor, injectors, etc) from the 92 on the 90 motor, as the 90 motor & car has all non-OBD components on it. Otherwise, same longblock but with different trannys (from 90-91 and 92-93).
Old Sep 16, 2003 | 04:48 AM
mr.beeks's Avatar
Default Re: 2nd Gen Acura (Newman)
just transfer all the guts from your
90 to the 92 make sure u use all of your electronics from the 90
Old Sep 16, 2003 | 07:14 AM
MAV3RiCK478's Avatar
Default Re: 2nd Gen Acura (francisco flores)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by francisco flores &raquo;</TD></TR><TR><TD CLASS="quote">just transfer all the guts from your
can't do that here francisco flores, like Newman said he has to use the OBD1 equipment from the 92 and the block from the original car. it will never pass smog visually, stupid hippies, we're all SOL here in cali!
Old Sep 16, 2003 | 09:52 AM
92 GSR's Avatar
Default Re: 2nd Gen Acura (MAV3RiCK478)
i thought they had OBD2 or is that just on GSR's
Old Sep 16, 2003 | 09:55 AM
TeamSTEALTH GSR's Avatar
Default Re: 2nd Gen Acura (92 GSR)
obd2 came on 96+ tegs
Old Sep 16, 2003 | 10:24 AM
93GSRB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">Same motor, different electronics. The 92 Integra will be using OBD-1 components and electronics so you'll need to use the components (ECU, distributor, injectors, etc) from the 92 on the 90 motor, as the 90 motor & car has all non-OBD components on it. Otherwise, same longblock but with different trannys (from 90-91 and 92-93).
i maybe wrong.. but i thought the 92 Integra is OBD0
Old Sep 16, 2003 | 10:28 AM
Newman's Avatar
New User
Default Re: 2nd Gen Acura (93GSRB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93GSRB17 &raquo;</TD></TR><TR><TD CLASS="quote">
i maybe wrong.. but i thought the 92 Integra is OBD0 </TD></TR></TABLE>
Nope, 90-91 Integras are OBD-0. 92-93 Integras are OBD-1. You can also use 94-95 Integra parts/electronics in a 92-93 Integra as well, as they're compatible. Likewise, you can use some CRX or 1st gen B16 parts in a 90-91 Integra as they're all OBD-0.
tonys2teg
Mid-Atlantic (Sales)
Mar 6, 2007 10:47 PM
