I saw this question before but I can't find it....fan keeps running after car shuts off!!
Old Sep 15, 2003 | 04:27 PM
toyotaturbo's Avatar
Default I saw this question before but I can't find it....fan keeps running after car shuts off!!
I just need to know which relay it is and where it's located. The fan occasionally runs after the car is shut off. Sometimes it even starts up as you're walking away from the car. Any info is appreciated.
Old Sep 15, 2003 | 04:30 PM
hndarcrb18c1's Avatar
Default Re: I saw this question before but I can't find it....fan keeps running after car shuts off!! (boost
Its suppost to do that.....
Old Sep 15, 2003 | 04:45 PM
x00gsr's Avatar
lboost_dependent .. Hope your car overheats.
Old Sep 15, 2003 | 04:49 PM
News to me. Since when? I've had other Integras, and not once did the fan continue to run.
Old Sep 15, 2003 | 04:50 PM
My car doesn't overheat. I hope yours blows up if it hasn't. I didn't come here to computer fight. I came here for advice from other Integra owners.
Old Sep 15, 2003 | 05:02 PM
x00gsr's Avatar
Learn how to use the Search Engines. Look up COOLING FAN.. Oh yeah, I Hope you Get in a wreck and DIE...Lol...
Old Sep 16, 2003 | 06:19 AM
WOTTEG's Avatar
A classmate of my girfriend's had lighting strike the ground real close to her car.
Her fan does as you describe.
Old Sep 16, 2003 | 06:57 AM
beaterman's Avatar
the fan stays on so your engine will cool down faster. i think it is pretty much common sense to anyone that has any mechanical or technical knowledge.
Old Sep 16, 2003 | 07:13 AM
opi's Avatar
opi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost_dependent &raquo;</TD></TR><TR><TD CLASS="quote">News to me. Since when? I've had other Integras, and not once did the fan continue to run.
My old DA never did that, but we do have a 91 prelude that does it all the time. yeah it is to cool the engine off after "long" drives i guess, like a NA turbo timer it usually stays on for a couple of minutes, than it shuts off. never "drained" the battery or anything if that's a concern. as to answering your 1st question, i'm not sure which relay would do that, or how to disable that...unless you want to hook up a switch to the fan to manually turn it on/off, or just leave it constant...good luck
Old Sep 16, 2003 | 07:17 AM
tilt's Avatar
uhm, neither of my cars ever do that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterman &raquo;</TD></TR><TR><TD CLASS="quote">the fan stays on so your engine will cool down faster. i think it is pretty much common sense to anyone that has any mechanical or technical knowledge.</TD></TR></TABLE>
Old Sep 16, 2003 | 07:48 AM
wcsinx's Avatar
Typically with electric fan setups, the radiator temp sensor and fan motor are not on ignition switched power. Meaning they can come on whenever. The purpose of running the fan after shutoff isn't to cool the engine (think about it, the water pump isn't moving) but rather to cool off the water in the radiator so that it doesn't boil/overflow/belch. Every car with electric fans I've owned was like this. Some cars just do it more than others. It depends a lot on the setup and condition of your cooling system as well as the ambient temperature. You might try flushing your coolant if you think it's happening too often.
edited to add: Almost forgot, when I changed my '76 Corvette over to electric fans, the instruction supplied by Spal said specifically NOT to hook the fans up to ignition switched power. They're powered directly from the battery. And if I'm fiddling with the engine when it's still hot, you'd better believe I pull that wire loose.
Old Sep 16, 2003 | 10:25 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
older Hondas are wired this way, newer ones (94-up Integras specifically) are not. If you have a newer Integra and the fan comes on with the car off, then you have a wiring problem.
724chris
Oct 12, 2010 09:49 AM
la_teta
Oct 5, 2010 02:49 PM
technine
Mar 19, 2009 04:12 PM
ben_l
Feb 23, 2009 08:57 PM
Kashi
Apr 13, 2005 07:09 PM
