resistor box removal(already searched)
a freind of mine has a 94 vtec prelude.he has 15 ohm 440cc injectors.i assume you can just remove the resistor box by hooking the 4 power wires that come from the box to a more powerful ignition source than the one wire coming in the box,correct?
Yes, what you`ll need to do is just cut the one power source from the resistor box and splice 4 wires to them, then run them to the Injectors.
You want to do the following-
Currently, the lude has a box with five wires. Four are the same (red/black) and one is different (yellow/black). If you are switching from low to high imped. injectors without changing the requirements of the ecu, then you would remove the resistor box, and connect all five wires together. Don't worry about finding any ignition sources or the like; you will probably end up with headaches.
