power steering leak
I have a power steering leak that is getting ridiculous. I have checked everything except the pulley on the pump. Is there a seal where the pulley is on the pump. If so can it be replaced or will I have to buy a new pump. It leaks somehow onto the pulley and then gets flung everywhere. It is a small leak but noticible. I replaced the o-ring on the clover bolt but to no avail. Also, can I use a power steering sealer? I can't find one that is for honda's so I was wondering if it would be OK to use something like Lucas power steering sealer, etc... any suggestions?
i would not use any kind of stop leak crap. if it's leaking at the pulley, the unit needs to be replaced. you may be able to take it apart and buy a rebuild kit, but it wouldnt be worth it. a new one cant be to spendy, or try a junkyard.
tominos
Nov 28, 2002 10:20 PM
