to anyone who uses aftermarket cams
im going to switch out the cams in my 5th gen lude this coming fall/winter and was wondering if anyone had any advice on which ones were better than others.right now im leaning towards the type s cams .
i have a 97 base prelude with AEM cold air intake,AEM pulleys,Tanabe hyper medallion exhaust,Ractive header,RT high flow cat,MSD 8.5 plug wires ,Denso irdium plugs,and when i have the cams installed a port and polished head, vtec controller, cam gears,new timing belt and an accord euro r intake manifold will be installed.
i tuned a 98 base prelude with about the same mods you have except he had a RC bored out throttlebody, V-AFC, straight-pipe, stock cam gears, stock intake manifold, and stock head...he put down 196 WHP with type-S cams.
I have the Crower Stage 2's with springs and retainers, and they make good power all the way to my 8100 redline, 195 whp on a 3rd gear dyno. Just make sure after you get them you get it tuned before you rev it into VTEC, you'll be way lean.
94VtecMN:
What are your mods? 195whp is pretty nice for Crower Stage 2's and I assume the usual I/H/E? V-AFC?
I have a 94 Vtec too w/just I/H/E and I am interested in Crower Stages 2's.
Did you ever dyno it B4 the Cams? Just Curious what that mod alone picked-up for your WHP.
THANKS!
PS: were you the guy who had to file down some places to get the Crowers to fit - was that a real pain in the *** or what? Is directions for doing that or a write-up?
THANKS!
My mods are the usual, DC DAC Intake, DC CC 4-2-1 Header, stock cat(ouch), Greddy PE exhaust, AEM underdrive pullies, Dinan chip(8100 redline), V-AFC, Type-S pistons, Eagle rods, Manual tensioner conversion, and the Crower top end.
I did not do the install of my cams, but my builder who did explained that all the rockers needed to be ground a little to miss the titanium retainers. It's a bit of a pain, but if you know it going into it in advance, it's not too bad.
As for before numbers, it's hard to say exactly what I got, I'll explain. I put down 176whp before, on one shops dyno who did 3 runs in 4th gear, and the 195whp after was on a different dyno done in 3rd gear. The guy that tuned my car to 195 said everyone that goes to the other shop always dyno's higher there. Why? I'm guessing the 3rd vs. 4th gear, and maybe some other factors. So, with that said, I figured the nearly 20 whp I gained was pretty good. I want to go back to the other shops dyno just to get an apples to apples comparison soon.
if i go with the crower what kind of valve train do i get? whats a dual spring compared to single?i plan on going with a 50 shot of NOS do i need valves too?and is there anything else i need ?
preludeshdriver
Sep 4, 2005 05:43 AM
