oil leak in spark plugs
Old Sep 15, 2003 | 11:03 AM
lke2drvgsr's Avatar
Default oil leak in spark plugs
a while back when i went to paint the valve cover, the 1st spark plug hole was filled to the top with oil... we cleaned it out, put in a new valve cover seal, and its been all good since then.. went to change my spark plugs/wires last night, and when i pulled 'em, the spark plugs were soaked in oil... all 4 of 'em.... im making power up to 9k (fully built engine), and the only time smoke is seen is when i'm flooring it, in which case my friend told me he once saw a blueish smoke come out... could it be blown headgasket or crack in the block? if not, what else could it be???? any help would be appreciated, thanks.
Old Sep 15, 2003 | 11:10 AM
J337_UNIT's Avatar
Default Re: oil leak in spark plugs (lke2drvgsr)
sounds like you need new rubber o rings for the valve cover...take off the valve cover and you should see these O rings for the spark plug holes...mine leaked as well but then i replaced them..no more leaks.
Old Sep 15, 2003 | 11:16 AM
lke2drvgsr's Avatar
Default Re: oil leak in spark plugs (J337_UNIT)
i replaced those when i replaced the valve cover gasket.... ill take it off, my friend said to try tightening the **** out of the bolts, maybe they're loose... thanks tho
Old Sep 15, 2003 | 11:22 AM
96IntegraLS4DR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lke2drvgsr &raquo;</TD></TR><TR><TD CLASS="quote">i replaced those when i replaced the valve cover gasket.... ill take it off, my friend said to try tightening the **** out of the bolts, maybe they're loose... thanks tho </TD></TR></TABLE>
Careful when tightening those bolts.
It's not good to snap those bolts, the key here is consistency with the torque wrench.
Old Sep 15, 2003 | 11:47 AM
91tegrals's Avatar
is ot possible to have just one seal leak cause ,y #3 pistons burns iol like a bitch but the motor seems to run fine but it will foul out the plug withen a week of changing it so i was wondering if that could be my prob and would it make youre car smoke really bad...
Old Sep 15, 2003 | 11:48 AM
JimBlake's Avatar
Default Re: oil leak in spark plugs (96IntegraLS4DR)
I don't think tightening will help. On mine, the gasket sits in a groove, & when you install the VC the metal NEXT TO the groove clamps down. So by overtightening the VC nuts, you're just cranking down on the metal-to-metal contact. You're not compressing the gasket any further.
Look for defects in the surface of the gasket. & defects in the surface that it mates up against.
Old Sep 24, 2003 | 11:16 AM
lke2drvgsr's Avatar
Default Re: oil leak in spark plugs (JimBlake)
ok well as it turns out, im burning a helluva lot of oil... the dipstick was DRY when i checked it today theres still blue smoke coming out, and i knwo it cant be the gromets, cuz ALL FOUR spark plugs have oil on them... could it be valveseals or piston rings? there's just oil on the bottom 3 threads of the spark plugs, there's no oil on top.... i'm also runing extremely rich, but im getting it tuned soon. im really startin to worry here..
Old Sep 24, 2003 | 12:23 PM
91tegrals's Avatar
yeah thats how my #3 plug is the bottom is coated in oil but im not sure were it is coming from i dont know if that much oil couild get through the rings and stll have it run so i was thinking maybe valve seals....
Old Sep 24, 2003 | 12:28 PM
lke2drvgsr's Avatar
Default Re: (91tegrals)
yea but ONLY your #3 has oil... all 4 of mine have it, so it can't just be the orings/gromets in the valvecover... its gotta be something big, and i dont think it's the piston rings, unless all 4 piston rings are bad....
Old Sep 24, 2003 | 12:31 PM
91tegrals's Avatar
yeah how does the car run i mean my car runs fine but burns a hell ofa lot of oil so im just throwing my prob out there looking for a answer..
Old Sep 24, 2003 | 06:10 PM
lke2drvgsr's Avatar
my car runs good.. there is some ticking, but as far as making power, it's making it up to 9k and overall its pretty smooth.. i beat on it quite frequently, its held up pretty well ::crosses fingers::
Old Sep 24, 2003 | 07:53 PM
Chemicalviper's Avatar
They are called rubber grommets or sparkplug grommets - do all 4 - clean out the rims with a q-tip to get the excess oil out.
Old Sep 24, 2003 | 09:44 PM
Gerhard_001's Avatar
Blue smoke is an indication your piston rings may going bad. Get a leak down performed on your engine, this will tell you if your piston rings are starting to fail. You also mention your are runnning rich, Do you have a custom ECU, VAFC, etc.......That could also be causing you these problems. I would take it easy on the car until you can source the problem.
Old Sep 25, 2003 | 08:46 AM
lke2drvgsr's Avatar
Default Re: (Chemicalviper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chemicalviper &raquo;</TD></TR><TR><TD CLASS="quote">They are called rubber grommets or sparkplug grommets - do all 4 - clean out the rims with a q-tip to get the excess oil out.</TD></TR></TABLE>
as i said before, i highly doubt ALL FOUR grommets would have gone bad at the same time.. it's gotta be something big that could leak oil into all places (which i cant possibly think of anything..) the bottom 3 threads of the spark plugs are wet, the tops are mostly dry....
as far as the leak down test, i'll try that. i have a mugen chipped ecu (garbage), and im getting my s200 hondata installed and tuned soon (i've been waiting to do this for months). thanks for the help guys! much appreciated
Old Sep 25, 2003 | 09:08 AM
I know they were just looking for the name of them -just sayings, its not gonna be the grommets.
Old Sep 29, 2003 | 06:13 PM
lke2drvgsr's Avatar
ok well i've still got that oil leak goin on.. but there's an issue with the damn starter. (its been like this for a long time, i just never bothered to do anything about it, but now its gettin bad) everytime i go to start it, (i have a new starter, msd ignition stuff), it goes WAAAA like an electrical type thing, but nothing turns over nor does anything attempt to turn over, it just gives me that annoying sound... it randomly does it, sometimes it does, sometimes it doesnt, sometimes it just does it once and i start it up right after that, sometimes i sit there for 20 minutes and its still goin WAAAAA anyone ever had this weirdass problem??? right now, = and lol
Old Sep 29, 2003 | 06:25 PM
HaUTSaauce's Avatar
New User
i have had all 4 grommets go bad when i bought a used valve cover so anythings possible
Old Sep 29, 2003 | 06:27 PM
lke2drvgsr's Avatar
Default Re: (HaUTSaauce)
yeah but all the grommets were just replaced when i painted the valve cover, along with the valve cover gasket.
sa21199's Avatar
Do a compression test right away. Your rings are going. Same thing happened to me.
Old Sep 29, 2003 | 07:25 PM
sinatra's Avatar
First off. Leakdown will let you know alot. My first guess (because I have researched it alot and am going through it right now with my car) is your oil rings are going. A compression test will not really reflect the problem you are facing with the oil rings. Second problem; hard starting is a known problem with aftermarket ecu chips. My car does it every now and then. A few other people I know have the same problem. It is a fact of life with an aftermarket ecu chip. Get your rings done. My money is on those failing.
preludebro
May 1, 2011 09:39 AM
dismemberment
Feb 18, 2009 02:51 PM
square_1
Jul 21, 2006 11:14 PM
thatasiankidtony
Jul 13, 2006 09:48 PM
si foo
Apr 27, 2002 06:32 PM
