I am thinking about getting Toda C camshaft...Who has it??
1. I wanted to find what i need to upgrade to spec c...aand what parts work best with it.
2. Is the horse power alot more that the b...
3. what kind kind of horse power am i suppose to get.....
Compression Hungry
Must flow well in/ex
Tuning, Tuning, Tuning
Not considered a daily driver cam
Dont go with the C just because its the most expensive. Its also the least forgiving.
It will make more power and peak farther out in the rpm range.
They are just as good a daily driver cam as the Bs are. Since the low cams
are the same, you will get the same midrange, but some more power up
top. You will need more fuel and as mentioned already some good tuning.
High compression wouldnt hurt either.
Boost2NA
10
Jan 7, 2004 06:25 PM
pierrot le fou
Nov 27, 2003 08:52 AM
