out of gas at high RPM's.. Not good for my motor!!!
I have a problem with my car (civic '96 w/b16a) running out of fuel after slowly bringing up the RPM's. It usually happens in 4th and 5th gear at 4-6grand. After doing some research I found that it most cases my fuel pump should be fine. I have a stock motor (K&N, MSD, P61?ECU) Could it be a dirty fuel filter? Anyone else run into this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah »</TD></TR><TR><TD CLASS="quote">get a FPR & gauge. set idle FPR to 48-51 i think it is? someone correct me.</TD></TR></TABLE>
Probably set it a little lower than that, as the motor is pretty much stock. Maybe around 42-43
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djaric »</TD></TR><TR><TD CLASS="quote">wtf are you doing at 4-6 grand in 4th and 5th gear? 4th gear, yea but 5th?
it's called Hwy Driving..
anyway; the problems isn't all the time.. only sometimes.. seems if I'm holding at a certain rpm for a period of time, then matt it, it'll happen.. going hard through the gears has no effect.. I know eventually I'll need to get a FP gauge to see what's happening, but just thought someone might have fell into the same situation..
</TD></TR></TABLE>it's called Hwy Driving..
Yeah, might as well replace the fuel filter. I have a friend that replaced his 20,000mi ago, and just had to replace it again. This on a 210whp all-motor car.
