need help fast!! adjusting valves on GSR
Old Sep 15, 2003 | 09:07 AM
Train's Avatar
Default need help fast!! adjusting valves on GSR
i need help in determining where Top Dead Center is on the #1 cyl. i know theres a white TDC mark on the crankshaft pulley, but how do i know when that thing is sticking straight up whether the #1 cyl is at TDC, or #2, 3, or 4 is at TDC? i called honda and the guy there confused me even more. i need to go to class at 4:45 (est) so i need help fast!
can anyone help me out? maybe a how-to with pics?? i'll search too. thanks.
Old Sep 15, 2003 | 09:15 AM
showtymers619's Avatar
* B A N N E D *
Default Re: need help fast!! adjusting valves on GSR (Train)
well take your valvcover off.. theres pointers on the cam sprokets... and to even make sure look at the cylinder # 1 and see if the lobes are completely off the rockers you should see the rounded partfacing the rockers and the pointed part of the cam up
Old Sep 15, 2003 | 10:12 AM
BeesDA6's Avatar
Default Re: need help fast!! adjusting valves on GSR (ShowTymers619)
Get a long screwdriver or a wooden dowel & put it in the spark plug hole. You know its tdc when the dowel or screwdriver is raised up. But do it carefully
Old Sep 15, 2003 | 10:24 AM
Train's Avatar
Default Re: need help fast!! adjusting valves on GSR (BeesDA6)
thanks. i got them checked.
Old Sep 15, 2003 | 10:27 AM
Mt3c's Avatar
25 Year Member
good how to.
http://www.c-speedracing.com/howto.php
Old Sep 15, 2003 | 07:20 PM
Train's Avatar
Default Re: need help fast!! adjusting valves on GSR (Mt3c)
thanks. actually, i found that site in the middle of the process, and it helped a lot better than muy haynes manual. good site
Old Sep 15, 2003 | 07:32 PM
deepgreengsr's Avatar
you don't need to use a screwdriver to find TDC for Valve adj. Sense the VC is already off just look at the cam. Is the lobe pointed up? then the base circle must be down on the rocker. adj the valves like that. Im a Tech I make money by working fast. That is how to do it fast. and SIMPLE!!!
Old Sep 15, 2003 | 09:33 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: need help fast!! adjusting valves on GSR (deepgreengsr)
yep my friend and I held a double valve adjustment session on both our cars this past Saturday. With him working the feeler guage and me using the valve adjustment tool, we checked and adjusted the valve lash in about 30-45 minutes per car.
str8jdm01
Apr 29, 2010 01:35 PM
thebleek
Oct 1, 2008 08:03 AM
h22aCrxSir
Nov 18, 2007 02:18 PM
