Outer Molding Around Radio,Climate Controls and Clock
Old Sep 15, 2003 | 08:56 AM
tarheelborn's Avatar
Default Outer Molding Around Radio,Climate Controls and Clock
From an earlier post, it seems that I need to remove this outer molding before I can get the clock out of the dash. There are 2 screws on the bottom that I did remove, but the molding still acted like it didn't want to come out. It was getting hung up on the top side. Is there some kind of trick to removing this molding?
Old Sep 15, 2003 | 09:21 AM
1994AccordSiR's Avatar
Default Re: Outer Molding Around Radio,Climate Controls and Clock (tarheelborn)
a screwdriver or other prying instrument
Old Sep 15, 2003 | 05:25 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tarheelborn &raquo;</TD></TR><TR><TD CLASS="quote">From an earlier post, it seems that I need to remove this outer molding before I can get the clock out of the dash. There are 2 screws on the bottom that I did remove, but the molding still acted like it didn't want to come out. It was getting hung up on the top side. Is there some kind of trick to removing this molding?</TD></TR></TABLE>
If this post is in reference to a 2000 and up Accord clock ... then ... NO ... you do not have to remove the bezel to get the clock out. All you need is a 1 1/2" putty knife and a shop rag. Just put the rag on the knife and slide it gently under the clock. Pry up and kinda pull it towards yourself and it will pop out. You then just disconnect the 2 connectors on the back ... flip it over ... unscrew the bulb ... screw new one in ... hook connectors back up ... pop back into dash ... reset your clock. WALAH!
JackRabbit
Nov 7, 2008 11:33 AM
simplyrob
Aug 19, 2006 12:23 AM
quantum_05em2
Honda Civic (2001 - 2005)
Jul 22, 2006 03:46 PM
SpoonSpecR
Sep 17, 2003 02:07 PM
charjacq
10
Feb 16, 2002 07:23 AM
